Old 10-08-2023, 12:27 PM   #1
northernwinds
Drives: 2020 Chevrolet Camaro 3LT RS 'Vert
20" Carbon wheels - looks like the clear coat is flaking off...
Anyone else experienced this? Seems to be on just one spoke, rest of the wheel (and the others) are fine...
northernwinds is offline   Reply With Quote
Old 10-09-2023, 07:35 AM   #2
JimGnitecki
Drives: Chevrolet Camaro LT1
Are you sure that's not an indication of an internal fracture? I's send a photo of it to the wheel manufacturer ASAP and ask that. IF it indicates a fracture, you do not want to be driving on that wheel.
Jim G
JimGnitecki is offline   Reply With Quote
Old 10-09-2023, 08:43 AM   #3
northernwinds
Jim G
There's no indication of a fracture or any sort of marring/damage that I can see, I've seen it on other painted wheels just wasn't sure if anyone had experienced it. It's the factory 20" Camaro wheel, I might run it by my local Chevy dealer and see what options I may have... also, the different color in the corner is just a reflection of my knee - it's not damage/discoloration of the wheel
Old 10-09-2023, 02:46 PM   #4
JimGnitecki
If you present this to your dealer as a potential safety issue, he might replace the wheel undewr warranty out of liability concerns.
Jim G
Old 10-10-2023, 08:37 AM   #5
fj5gtx
fj5gtx's Avatar
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1
You can likely repair that with a little sanding (1000 grit) and some clear coat, Dealer might refer you to a wheel repair specialist they use for their used fleet. Or just pick up a new or nice used wheel. Is it a 8.5 or 9.5?
2022 CAMARO LT1 COUPE AT10
fj5gtx is offline   Reply With Quote
Old 10-11-2023, 01:30 PM   #6
The Chief (tm)
The Chief (tm)'s Avatar
Drives: 2016 Camaro 2SS "Convertibobble"
Jim G makes a very good point there; if you swing in and are able to pose the question in that fashion, you may end up with a brand-new wheel. Worst case, you come away empty-handed, having spent ~10 minutes of your time, and *then* proceed onto whatever was to be the next step anyway...
'16 2SS Garnet Red ~24K
"Mods": GM wind deflector, home-made rear seat delete & platform, not-quite garnet red key fob cover (+10rwhp)
'99 4Runner 367K
'94 ST1100 146K
The Chief (tm) is offline   Reply With Quote
