Old 10-04-2023, 10:10 AM   #1
Tbone98
Tbone98's Avatar
Drives: 2023 Sierra AT4, 2024 Camaro 2SS
Skip Shift Eliminator
Plan on installing an SSE tonight. Is it really as easy as plug an play, or are there some software/coding updates needed before driving it?
2024 Camaro 2SS CE, M6, Panther Black Metallic Tincoat
Tbone98 is offline   Reply With Quote
Old 10-04-2023, 10:53 AM   #2
Ruby13
Ruby13's Avatar
Drives: 2019 2SS/1LE Shadow Grey
Just don't plug it into the reverse lock out, same style plug on the tranny, the one you need is higher up
Ruby13 is offline   Reply With Quote
Old 10-04-2023, 11:02 AM   #3
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
hardest part is getting yer' fingers in there
plug & play
Old 10-04-2023, 11:22 AM   #4
Tbone98
Tbone98's Avatar
"higher up" meaning closer to floor pan, or closer to engine?
Any pics on correct and incorrect?
Thanks for the advice
Old 10-04-2023, 12:39 PM   #5
Idlefury
Drives: 2016 Camaro 2SS, 1969 Camaro
It's up near the floorpan. I had to use a long screwdriver to help disconnect/reconnect the plug because my hands didn't fit. Other than that, it's very simple. Takes longer to get the car on the ramps or jackstands than it does to install the SSE.
Idlefury is offline   Reply With Quote
Old 10-04-2023, 12:40 PM   #6
Callaway SC630
Callaway SC630's Avatar
Drives: 2020 Callaway Camaro SC630
This link has some pics to help:
https://www.southerncarparts.com/201...or-p-8750.html
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue
Callaway SC630 is offline   Reply With Quote
Old 10-04-2023, 01:36 PM   #7
haggler
haggler's Avatar
Drives: '23 2SS RSblue 6MT, sold '19 ND2
It depends how the clip of the original plug is oriented. In my case it was actually facing upward, which took this from a 5 min process to more like 30 min. What saved my ass was having a 90 degree pliers because my hand could not fit in that space. I was able to unclip it with the pliers by leveraging it against the case of the transmission and expanding the pliers. I used a separate screwdriver to loosen and unplug it once the clip was undone.
I'd also recommend getting the version of this which has the cable attached rather than than just the plug separated from the female side. It makes it easier to work with and zip tie the harness. Good luck.
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars
EOS front splitter
5-6-22:1100,
7-19-22: 3000,
8-3-22: TPW 8/15/22,
10-4-22: ETA 10/13/2022
10-15-22 6000
haggler is offline   Reply With Quote
Old 10-04-2023, 04:26 PM   #8
Tbone98
Tbone98's Avatar
I got the Phastek "T56 & TR6060"
Old 10-04-2023, 04:30 PM   #9
Tbone98
Tbone98's Avatar
Originally Posted by Callaway SC630 View Post
pretty much what mine looks like. Thank you. I was going to attempt this on jack stands, but seems like my life will be easier if i use a lift
Old 10-04-2023, 05:06 PM   #10
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Normally a lift makes everything easier, but this job is just a arms length up, and straight up. So laying on your back and reaching straight out in front of you is probably "ergonomically" better. Just a PIA narrow spot. Good lighting and a bevy of tools and you'll be fine!
Ventmaster is offline   Reply With Quote
Old 10-04-2023, 10:05 PM   #11
50MileSmile
Drives: 2023 2SS, 2018 1SS 1LE, 1993 Z/28
The instructions that came with my skip shift say it installs on the driver’s side of the transmission, but the module to switch out and the reverse module were both on the passenger side. What do your instructions say?
50MileSmile is offline   Reply With Quote
Old 10-05-2023, 12:03 AM   #12
Tbone98
Tbone98's Avatar
Didnt get to installing but I believe I read driver side
Old 10-05-2023, 07:30 AM   #13
LT1gen6
LT1gen6's Avatar
Drives: '22 LT1 Coupe
The undeniable best skip-shift eliminator is simply the driver's right foot. Shift at 20mph+, and defeat the force skip.
Next best is the driver's right hand, either by shifting to 3rd gear, or preferably by slightly entering the lateral pathway to gears 3-4 and shifting to 2nd.
Pick any of these 3, practice 30 times to develop a new habit, and forget that 1-4 forced shifting even exists.
LT1gen6 is offline   Reply With Quote
Old 10-05-2023, 09:30 AM   #14
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
surprised it took 13 posts, lol.
