![]() ![]() Drives: 2019 2SS Camaro Join Date: Apr 2012
LT1 vs LT4 HPFP
Would an lt1 hpfp with a bigger cam fuel lobe get close to the out put of an lt4 pump with a stock fuel lobe?
#2 | |
Moderator
Kerry, why don't you just get the TooHighPsi port injection, run E and you can turn down your High and low side and you won't have to worry again. Run about 70 percent DI and 30 percent PI.
#4 | |
Both my low side was dropping JMS booster fixed that. Then the high side was dropping but lt4 pump and injectors fixed that. have a stock cam so always trying to learn and experiment. its a hobby. No doubt the toohighpsi port is the bomb. very good option but at my power and set up I just dont need it. hence my question is would the lt1 pump with cam lobe do as well as lt4 with stock lobe. it would be great very helpful if someone could answer that. I would have to change the cam to really anser that. It aint that much of a hobby LOL. Being I put in the lt5 cam as I like stock valve train, and wanted to do away with the dod system. and whoever said that it was same as lt1 cam just not dod. Now BTR says its more like an lt4 cam. So I would think the lt1 spec cam they have would work better for me with the lobe. Then i would not need the lt4 pump sell that pays for the upgrade. |
#5 | |
Moderator
#6 | |
And u can turn the pressure in a middle ground as well. So i don't know. pump can drop to 2500 and still i have plenty of fuel but much lower is a no no. Thanks for ur reply. Any help is much appreciated!
#7 | |
Moderator
#8 | |
![]() The car runs like better than i ever hoped someone help me to just let it alone. ![]() ![]() ![]() ![]() ![]() ![]() :: ![]() raped ape scaled dog ect ect.
