Old 09-30-2023, 09:59 AM   #1
rjgss
Drives: 2016 Camaro SS
microphone not working
Just bought a 2016 SS and my voice is not being detected; checked mic and wire is connected and its attached to pillar trim. Is there a setting to get it to work or what is fix. I understand these mics suck but my voice isn't being detected with car running and with it off
Any help would be greatly appreciated
rjgss is offline   Reply With Quote
Old 11-29-2023, 08:02 PM   #2
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Check and see if the Onstar system is operational. If not, it’s possible the fuse has been pulled under the hood.
I have my Onstar fuse pulled and the side effect is that the microphone no longer works.
Old 12-11-2023, 07:08 PM   #3
rjgss
Thanks guys, I thought about a mute button but from what I can tell its the hang up button on the steering wheel. I will research those other ideas, worth a shot
Old 12-15-2023, 11:48 AM   #4
LTfun
Drives: 2022 LT1, 1981 320i
If you're not the first owner, its possible someone's method to interfere with GPS and/or on-star has turned off the mic as an unintended consequence. IIRC they share the same 5V power supply.
LTfun is offline   Reply With Quote
