Old 09-20-2023, 11:21 PM   #1
Redwings1
Drives: 23 ZL1, 22 C8 Sold. 21 LT1 Sold
How to 0-60
What the easiest way to get the best 0-60 time. Turn off nannies?, leave in drive?, track mode-sport mode? What does everyone do?
Redwings1 is offline   Reply With Quote
Old 09-21-2023, 01:45 AM   #2
Z06ZLE
Z06ZLE's Avatar
Drives: 2023 Camaro ZL1 M6
Try launch control mode.
2023 Camaro ZL1
2023 BMW i4 M50
2014 Mustang GT
2012 Yamaha R1
2011 Corvette Z06
2008 Corvette Z06
2007 Yamaha R6
Daily: 2015 BMW i3
Z06ZLE is offline   Reply With Quote
Old 09-22-2023, 12:24 PM   #3
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
I don’t think any of that matters for 0-60 as much as rolling into the throttle to transfer weight to the rear to put as much power down as possible.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 09-29-2023, 05:31 AM   #4
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
Launch control if you aren't trying to chase 1/10ths / duplicate what the car rags get. Remember those guys beat the shit outta those cars and have cumulative 1000's of launches. When it's your car and your money on the line, you tend to err to the side of caution.
With my 50th 'vert I was able to get down to 4.4s. On unprepped streets with UHP A/S tires and a M6, I'll take that. There are very few cars that are able to duplicate those 'best' numbers on the street. Go to YT and look up videos of people trying to do it, and you'll see your average joe can't do it.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 09-29-2023, 06:15 AM   #5
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
Unless I missed a mode, the problem with launch control is once you launch and shift, traction kicks in and kills power when shifting into second and so on. Maybe I just need better tires >.<
Old 09-29-2023, 06:43 AM   #6
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
^ this.
Old 09-29-2023, 07:15 AM   #7
cjperformance
cjperformance's Avatar
I've got a blower on my 2SS... I never get better than 4.0 seconds 0-60 on the street even with drag radials (no burnout and no street prep). Typical is about 4.2. Nannies off, rolling on about 30-60% throttle until 40 mph, then WOT.
Tires and pavement are the limiting factor more than anything you can do with the car on the street.
Ive had "launch issues" with torque mgmt on the dragstrip, but so far getting 3.0-3.1 sec 0-60. Im betting that ill get sub 3 sec 0-60 once torque management sorted. Hopefully already is, just haven't retested at the track yet.
Point being, 0-60 on the street is a bit pointless. I dont even get WOT traction until 40+ mph.
I use 40-90 mph times as a more practical way to measure changes with mods.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 09-29-2023, 08:23 AM   #8
JSH
JSH's Avatar
Drives: '20 ZLE
For my build with MTETSR - Track mode, TC off, manual mode 2nd gear (although I might give 1st gear another shot), barely engage the throttle to say 1000 rpm, roll to WOT in say 1.0 sec., my last 0-60 in April was +/- 2.01 sec. per HPT.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 09-29-2023, 11:19 AM   #9
Moniker
Drives: ZL1
I found the launch control to be terrible. Put the suspension in tour mode, select sport mode, foot on the brake, bring the revs to between 1500 and 2000 rpm and launch. Mid 3 to 60 mph, low 11’s for the ¼ on unprepared surface. Search the forum there’s lots of good advice.
Moniker is offline   Reply With Quote
Old 10-01-2023, 10:04 PM   #10
ohsmily
Drives: '19 ZL1 1LE A10 ShadowGrayMetallic
My best is 3.7 on regular asphalt just mashing the pedal in track mode. 2019 ZL1 1LE A10.
ohsmily is offline   Reply With Quote
