Old 09-16-2023, 11:09 PM   #1
carlythecamaro
carlythecamaro's Avatar
Drives: 2017 Camaro SS
Question LT2 & Throttle body question
Just curious if these two items will fit together before I purchase. Also will the car need a tune after these have been installed? Thanks
https://www.solerengineering.com/gen...ors/se9871-100
https://www.texas-speed.com/p-9823-g...-manifold.aspx
carlythecamaro is offline   Reply With Quote
Old 09-17-2023, 11:05 AM   #2
s346k
s346k's Avatar
Drives: like an old lady
LT5 tb needs the adapter (or mounting holes elongated) to work on any LT1/2 manifold.
i ran a stock tb on my LT2 but i think the manifold needs to be ported to accept an LT5+ tb.
the car will need a tune to get the most out of it. might as well throw on a flex fuel sensor while you're at it if you don't have one already.
if it were mine to do over again i would just do a stock LT2 manifold and reuse the stock tb. i saw very little difference going from LT2/stock tb to msd/95. couple tenths of a second 60-130 at best. ymmv
Old 09-17-2023, 09:46 PM   #3
carlythecamaro
what will the flex fuel sensor do?
Old 09-17-2023, 09:52 PM   #4
Paired with a proper tune, it'll allow you to run ethanol (E85) for more power (40-50 extra hp), lower engine temperatures and cleaner combustion, at the cost of a 25% fuel economy hit.
Depending on the area you live in, ethanol may or may not be widely available, and it's typically priced 25-30% less than 93 octane gas, so still worth it overall even in terms of cost despite the worse fuel economy.
Old 09-18-2023, 02:35 AM   #5
s346k
s346k's Avatar
when tuned accordingly, it allows the car to be driven on e85, 93 octane or anything in between. worth 20-25 whp and about the same tq when ethanol content is above 60%.
Old 09-18-2023, 05:52 PM   #6
carlythecamaro
will I need a flex fuel sensor & flex fuel kit? or just one?
Old 09-18-2023, 05:52 PM   #7
carlythecamaro
Old 09-18-2023, 06:09 PM   #8
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Just the kit is fine. Usually comes with the sensor, wiring, and the fuel hose with connections. Makes the kit pretty straightforward to install that way…just need to enable the tune afterwards.
Old 09-18-2023, 06:52 PM   #9
6spdhyperblue
Drives: 2SS 1LE
Was that a glitch in the matrix
Old 09-19-2023, 04:00 PM   #10
wnta1ss
Drives: 2017 Camaro 1SS
Uh, the OP is building a bolt-on car, not a supercharged one. The gain from E85 on a bolt-on LT1 would be more like ~25 rwhp if his 93 tune is decent. Bolt-on car won't gain as much from the ethanol as the blower cars do.
Old 09-19-2023, 04:18 PM   #11
Oops, sorry, you're absolutely right. I'll read more carefully next time.
The other advantages still apply all the same, fortunately.
Old 09-19-2023, 04:24 PM   #12
driftking123
driftking123's Avatar
Drives: 2022 SS 1LE
If you are looking at Texas speed ($256), which is NOT modded. Why not order one from Rockauto for $187? You have to modify the intake on both, so I'd go cheaper. Just my 2 cents. Also go to ZZZperformance and get an adapter for the 95mm for $44
driftking123 is offline   Reply With Quote
Old 09-19-2023, 08:38 PM   #13
Daily1LE
Daily1LE's Avatar
Drives: 2018 Camaro 1SS 1LE
Just to make sure you're aware, you have to modify a few things on the LT2 to make it work. There's places that sell the intakes pre-modified if you're not sure what to do.
Also, def would consider flex fuel kit at the same time. I did flex fuel a few years back and now recently got an LT2 manifold. Now I gotta pay again for another tune after I get that installed. Holding off for now debating what else I want to throw on the car.
If you want a visual of what E85 can do, attached is my dyno graph. Green is CAI only, red is CAI and full exhaust, and blue is CAI, full exhaust, and E85. As you can see E85 had big gains everywhere.
2018 1SS 1LE - DSX E85 Kit | Full ARH Exhaust | RotoFab CAI | Katech Cam | Katech Ported Stock Heads | Tuned - 530HP/456TQ
Daily1LE is offline   Reply With Quote
Old 09-21-2023, 06:03 PM   #14
carlythecamaro
Modify the intake how? And I will consider using those options for sure. If I got the intake, TB & the adaptor what else would I need?
intake manifold, throttle body
