Old 09-16-2023, 03:56 PM   #1
RollyM
Drives: 2023 Camaro 2SS
MRR M017 20x10 square setup installed
After a bunch of research and seeing a couple square setups on here I pulled the trigger on 4 MRR M017 20X10 ET23 wheels and mounted 285/35/20 Michelin Pilot Sport All Seasons on them since this is a daily driver. Fits perfect and gives me a little more sidewall protection as well. Car rides and handles so much better than the staggered wheels with Goodyear F1 run flats. Side note, my car is a 2023 2SS with MRC. There is zero rubbing on anything even at full steering lock.
2023 2SS Shadow Gray, A10, Sunroof, NAV, NPP, MRC, RECAROS, Suede Steering Wheel, Red Calipers, MRR M017 Wheels, Morimoto smoke LED side markers, PPF
RollyM is offline   Reply With Quote
Old 09-16-2023, 04:04 PM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Nice, I've got a staggered set of MRR017's sitting in the garage ready to be mounted to the car (2020 2SS with MRC), I went with 305/30/20 and 285/30/20 (SS 1LE OEM size)...
With the +23 offset on the rear (vs. the +43 of the stock rears) are you getting some poke on the rear tires (tire at or beyond fender lip)?
They do look great, mine is Shadow Gray Metallic as well...
Old 09-16-2023, 04:11 PM   #3
RollyM
No poke at all since they are only 10” wide instead of 11” on the staggered setup. Offset makes up the difference.
Old 09-16-2023, 04:56 PM   #4
2SS Capt
2SS Capt's Avatar
Ah, that's true I guess... Look great either way!
Old 09-16-2023, 04:58 PM   #5
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
I actually like those and might have them someday. They look great dude. Do you think they are heavier or lighter than the stockers?
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60'
1998 Camaro Z28 A4 - Bolt-on
1999 Camaro Z28 A4 - Stock
Dynamical is offline   Reply With Quote
Old 09-16-2023, 07:15 PM   #6
RollyM
Wheels are about the same I think, but the tires weigh significantly less than the run flats.
Old 09-16-2023, 08:38 PM   #7
shoe5163
Drives: 2017 50th Anniversary SS
Is the diameter the same? Any codes throw or speedometer off?
shoe5163 is offline   Reply With Quote
Old 09-16-2023, 09:17 PM   #8
CTRifecta
CTRifecta's Avatar
Drives: 2SS 1LE
And shots of the tires from the rear?
Is it easier to light the tires up now that they're all seasons and narrower in the rear?
2024 2SS 1LE | 6MT | Riverside Blue
1100 - Order submitted - 7/12/23
2000 - Order accepted - 8/22/23
Vehicle Built (per chevy chat bot) - 10/10/23
Window sticker available online - 11/4/23
Arrived at dealership - 11/10/23
CTRifecta is offline   Reply With Quote
Old 09-16-2023, 09:31 PM   #9
2SS Capt
2SS Capt's Avatar
He went from 275's to 285's in the rear, so slightly wider now...
Old 09-16-2023, 10:11 PM   #10
CTRifecta
CTRifecta's Avatar
Drives: 2SS 1LE
D'oh! Good call, I thought he had a 1LE.
Old 09-16-2023, 10:21 PM   #11
2SS Capt
2SS Capt's Avatar
I'm going with the same wheels but in 1LE size, here is my current (275) rear tires (left) and the new 305's (right)...
I've got everything ready to go, even ceramic coated the wheels, just need to get them on the car, but the car is clean and it is raining out and I need it in the other garage bay to put it on the QuickJack, so I have to wait for another day...
Old 09-16-2023, 11:52 PM   #12
RollyM
No codes. The diameter is only 3.5mm larger so it’s less than 0.5% difference in speedo. A 285/30 is quite shorter compared to the original 245/40. That would’ve put the speedo off about 3.7%. Which was too much for me. A 275/35 is the closest, but I wanted a little more meat.
Old 09-17-2023, 12:45 AM   #13
2SS Capt
2SS Capt's Avatar
I THINK the speedo is connected to the rear wheels...
Old 09-17-2023, 08:33 AM   #14
RollyM
That’s probably true. Still less than 1% difference from the original 275/35.
