Old 09-16-2023, 12:26 PM   #1
Kerry
Drives: 2019 2SS Camaro
Plug Read
New plugs 5 min warmup then wide open 3rd and 4th shut down. What does everyone think how they look?
Plugs are 13572468
Kerry is offline   Reply With Quote
Old 09-16-2023, 12:59 PM   #2
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
The second one from the left looks a little lean, but with out close up photos and very little runtime, hard to tell
Old 09-17-2023, 09:43 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Can't really tell...the pics are too blurry.
If you are wanting to know rich or lean for WOT afr, you need to cut the threads off so you can see the bottom of the electrode porcelain. Bottom reading is wot afr, top is part throttle afr. Can't really see the ground straps to determine if the timing is in a good range. Heat range looks a touch hot.
I would suggest a TR-7ix at your power level and compression imo.
