![]() Drives: 2023 Sierra AT4, 2024 Camaro 2SS Join Date: Aug 2023
RR license plate mount
I'm sure this is easier then I am stressing about, but one of my 3 items I sent to the dealer as "no, no's" was to not drill holes in the front bumper for a license plate mount. WELLLL, they did not drill and/or add the RR license plate holes and anchors.
I pretty much assume its easy, but I am freaking about scratching the area. Has anyone done this before and can offer instructions? Do you drill one larger hole and push the square frame anchors through the round hole? Do you use a smaller bit and drill multiple holes to essentially make a square pop out? There are multiple dimples on the plate area but don't seem to be mirrored left to right thanks
2024 Camaro 2SS CE, M6, Panther Black Metallic Tincoat
![]() Drives: '23 1SS 1LE | '18 1LS V6 [sold] Join Date: Jul 2020
Can you take the car back to that dealer and have them drill the holes for ya?
I can, trying to save an hour drive on a crappy freeway before PPF
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
Did they supply the anchor clips for your license plate? If they did measure the width of the square tabs, drill a hole slightly smaller than the clips resting width and use a small square or triangle mini jeweler/finishing file to make it a square hole. you can always make it bigger but you can’t make it smaller so start small and work your way up.
![]() Drives: '23 1SS 1LE-Sharkskin M6 Join Date: Apr 2022
Just keep it hole less.............slap some red double sided 3M tape on it and never worry about the holes.
![]() Drives: 2022 2SS Join Date: Mar 2022
I think you are talking about the rear plate mount? The screws tap right into the rear fascia no anchors needed. There are several dimples, make sure you are centered on the right dimples for all 4, mark them through the plate holes, drill a small hole in each then screw in the screws. There is extra reinforcement behind each dimple in the fascia. Just be sure you are centered, I've seen dealers mount rear plates off center. I get stainless steel screws from Tractor Supply.
You show Michigan which does not require a front plate.
2022 Camaro 2SS (6000 Vehicle Delivered to Customer 4/7/2022) Build Date 2/28/2022 GAZ Summit White B04 Black Metallic Rally Stripes IOT Navigation MX0 A10 Transmission CF5 Power Sunroof SLN Strut Tower Brace 56V 20" 5-spoke Carbon Flash Metallic Wheels NPP Dual-mode exhaust VTD 2nd Gen Ground Effects Carbon Flash Metallic 1996 Corvette LT4 Convertible Collectors Ed SOLD 2004 Corvette ZO6 LeMans Commemorative SOLD |
#7 |
#8 | |
I had no idea that you could tap right into the bumper. Just seems not as secure as using the anchor clips. Is there a dealer tech on this site that can offer some insight? Yes I have the clips
#9 |
I strongly recommend a silicone plate "frame" similar to this one if you want to preserve your paint: https://www.amazon.com/dp/B0BNPV2VTZ?th=1
By the way, 100 out of 100 people screw the plate holder into the rear bumper, that's what the reinforced dimples are designed for. The reason there are so many is the different plate sizes and attachment points across the world.
#10 |
Hot Camaro
Do you have a local dealer that you trust? Have you asked them what they would charge to do the work?
From there, you contact the original dealer and tell them that they failed to complete a step required for delivery - ask them to cut a check in the amount of the other dealer's charge. If they refuse "offer" to let them send a technician to your house or to send a flatbed to transport you car back and forth. You just never know if you'll get a reasonable person on the other end of the phone or not.
#11 |
I got her done today. Took her to my old man’s house. He and I canoodled over it for a few minutes then found the simple and wend after it w the appropriate bit. Anchors popped in east and all good
#12 |
![]() Drives: 2023 Camaro 1SS M6 Join Date: Mar 2023
So just curious, you ended up drilling the front or back? If the back, I wouldn't be afraid to drill at all. It's meant to, like others have said. The front doesn't have to be drilled if you use the supplied plate bracket that I thought everyone gets in the trunk with the racing air deflectors or whatever they are.
It looks better than any aftermarket bracket I've seen honestly. Some of the other ones look cheap and tacky.
Black 2023 Camaro 1SS Coupe M6
Ordered: April 2022-----Built: July 2022-----Delivered: September 2022 -Dual-Mode Exhaust (NPP) -Red Painted Calipers (J6F) -5 Split Spoke Bright Silver Painted Aluminum Wheels (56W) -Chrome Camaro Logo Fender Badge -Second Generation Front Splitter in Satin Black |
#13 | |
#14 |
Okay, I gotcha. Yeah I can see why you might be hesitant. The dealer drilled out my rear and it came out just fine.
