Old 09-14-2023, 11:41 PM   #1
KB412
Drives: Former: 99SS M6, 91 Z28 M5
Elsd fluid change
I can’t find any service records saying mine was changed. 2022 3K miles. Just got it. Should i do it just to be safe.
Is this a track only necessity, or all. Sorry if this is a beaten up topic.
Any idea of dealer cost?
Thanks. Got it out for first real drive today. Blown away!
2022 VOM 2SS 1LE M6
KB412 is offline   Reply With Quote
Old 09-15-2023, 08:18 AM   #2
Briland_1LE
Briland_1LE's Avatar
Drives: 2020 Camaro SS 1LE
I bought my car with 7k miles on it and I never looked into the 1500 mile diff fluid change. I have 47k miles and a lot of trackdays so now that you bring it up I'm going to change that to be safe. I wouldn't worry about it, if anything change it before your first trackday.
Congrats!
Briland_1LE is offline   Reply With Quote
Old 09-15-2023, 08:29 AM   #3
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
you can do it for under $50
just change it for a baseline maint record
Old 09-15-2023, 08:32 AM   #4
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I didn't do my 1LE for like 30K, but the ZL1 I did it within a few thousand, partly because I knew it would be pretty easy. I don't have an opinion on when it's really necessary for a street DD. Piece of mind and there's a lot of gunk on the drain plug when you pull it.
Old 09-15-2023, 09:32 AM   #5
Camaro Fanatic
Drives: '23 1SS 1LE
+1 on changing it. Did mine after 1.5K and a lot of gunk was on the magnetic drain plug.
I'd say it's good peace of mind and you won't have to worry about it until you track it or 30K+ miles down the road.
2 jugs of fluid comes out to <$50 on Amazon and you just need a fluid transfer pump. Took <10 minutes after getting the car in the air.
Camaro Fanatic is offline   Reply With Quote
Old 09-15-2023, 09:58 AM   #6
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Change diff oil twice at the same time you do the 1st oil changes (500 and 3k miles or so). It gets really gunky in new ediffs. After that it'll be good, I did my 4th change at 39k miles recently and the fluid looked fine.
Old 09-16-2023, 12:46 PM   #7
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
This is what I did and third dump looked a lot better than the first two
Old 09-16-2023, 12:53 PM   #8
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Change it, cheap insurance, I did mine at 505 and again at 1,500 miles, at the 505 there was a lot of gunk on the magnetic plugs, 1,500 there was a bit... When I did it again at 5,975 the fluid looked great...
Super easy and not very expensive...
