Old 09-13-2023, 04:29 PM   #1
snakebit336
Drives: Camaro ZL1
Spoiler
Id like to change out my rear wing spoiler (low profile) for a blade spoiler but I've only found one online and there wasn't a lot info about it. Any recommendations or advice appreciated...2017 ZL1. TIA
snakebit336 is offline   Reply With Quote
Old 09-13-2023, 04:33 PM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
You have the ZL1 3 post stanchion spoiler, unfortunately the only blade spoilers made use different hole patterns compared to the SS/ZL1/ZLE.
There’s two hole patterns on the 6th Gen, the 3 post stanchion and the RS/Blade. They use different holes and to switch between the two would require filling or plugging the holes and drilling new holes
2016 1LT v6
- Totaled
Happiness: Infinite
Old 09-14-2023, 12:15 PM   #3
snakebit336
Drives: Camaro ZL1
I appreciate the reply...I kinda figured that but I wanted to be sure. I googled myself silly. Not sure I want any drilling or hole patching done just yet.
Old 09-14-2023, 01:04 PM   #4
eimarshall
eimarshall's Avatar
Drives: 2018 SS 1LE Hyperblue
Yeah, unfortunately the blade spoiler would leave the forward most holes from your spoiler exposed, AND require drilling of 6 more holes.......
I recommend trying to find someone that wants to swap trunks. Most of the SS 1LE guys end up wanting the ZLE wing(like I did). its not often a ZL1 guy wants the Blade spoiler, so you might find someone willing to swap if you put out some feelers in your region.
eimarshall is offline   Reply With Quote
Old 09-14-2023, 07:45 PM   #5
Kezos
Kezos's Avatar
Drives: 22 1SS 1LE
Pretty sure this acs one uses uses the holes from 3 post spoilers.
https://acscomposite.com/products/ca...r-deck-spoiler
2022 1SS 1LE M6 Summit White
Kezos is offline   Reply With Quote
