![]() Drives: 2021 ZL1 1LE with PDR Join Date: Oct 2022
Dipstick accuracy
This is my 3rd oil change, dipstick is always pretty low after 10qt. Like just inyo the cross hatching.
I see other threads on this but no general consensus on where it should land. I don’t want to put over. 10qt. But man, its low |
![]() Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
I've only done one oil change at 500 miles, but I put in exactly 10 quarts. Checked it the next morning when it was stone cold and it was exactly at the full mark. I think maybe people are not allowing sufficient time for all the oil to drain back to the pan.
ΜΟΛΩΝ ΛΑΒΕ
![]() Drives: Camaro ZL1 1LE M6 Join Date: Mar 2023
I had the same issue when first purchasing my car. Needless to say I looked across this website and others had posted that their dip stick oil level read full with 10 Quarts and others that it would be full half way up the dipstick. I didn't want to take the chance off too much oil, so the photo shows what it looked like sitting overnight, changed it the next morning and after adding 10 quarts mine read the same on the dipstick as in the photo. So almost half way up the dipstick is full for my car.
ZL1 1LE
#4 | |
![]() Drives: 2023 Silverado LTZ, 2022 Camaro 2SS Join Date: Jul 2010
After changing the oil and filter and putting 10 quarts in, mark your dipstick.
Currenent rides: 2020 SW ZL1 A10 2019 SW 2SS A10 2017 SW Silverado LTZ |
Dipstick is defective, the stop on The dipstick moved, see if it
Moves (up or down) on the metal part, that would give u an inaccurate Reading. |
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
My car changes over time after an oil change. After fresh 10 QTs of M1 15w50 + PF64 filter which always goes in prior to a track weekend, it's always at full top of fill mark tab. Throughout the entire track weekend of high temp driving in advanced group, lots of repeated long WOT pulls on long straights like ACS front up to 160 MPH and always 2 day weekends, my ZLE never burns a drop of oil. I bring it home and drive it on weekends in canyons for a few weeks and still doesn't burn a drop, then after a month or so I see it gradually start losing a little. My engine prefers to by run at full power, and oil temps in the 250+ range :-)
#7 | |
This is exactly what I see. |
#8 | |
![]() Drives: Camaro ZL1, Golf R Join Date: Feb 2022
’22 ZL1 Riverside Blue 6MT
’17 Golf R Limestone Grey DSG |
#9 | |
![]() Drives: 2023 Camaro ZL1 M6 Join Date: Apr 2023
2023 Camaro ZL1 2023 BMW i4 M50 2014 Mustang GT 2012 Yamaha R1 2011 Corvette Z06 2008 Corvette Z06 2007 Yamaha R6 Daily: 2015 BMW i3 |
#10 |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
Mine takes 11 every time. Don't know why, but that's what it seems to go with.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
834 HP/ 840 TQ |
