Old 09-08-2023, 05:53 PM   #1
pontiaco1
Drives: 2018 1LE
1LE Suspension Gurus come in
This is my 2018 1LE, FBO plus E85,
Suspension in bone stock. Was wondering about pictures, do I have a problem with body roll. On this races car never went over 45mph autocross
pontiaco1 is offline   Reply With Quote
Old 09-08-2023, 06:27 PM   #2
cdb95z28
cdb95z28's Avatar
To answer your question....No.
The SS 1LE has some body roll.
You are good.
Here's mine at Pitt Race. More speed, more loading, more body roll. Crazy fast.
"KEEP THE FAITH"-Fbodfather
Old 09-08-2023, 06:39 PM   #3
pontiaco1
Drives: 2018 1LE
I love that color
Old 09-08-2023, 08:32 PM   #4
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Almost any car is going to roll, with swaybars. There are a few exotic mechanical systems to outright prevent it, but it'll still squat a bit on that tire. Autocross is no different and you can still be pulling some significant Gs. We may not be going 100 miles an hour through a turn, but we are still loading the tires to the limit of what they can hold on to and you are damn sure going to roll the body some.
Sometimes, more roll is good to get weight transfer, but the big issue I have is the throttle is only linear in track and in any other setting it makes the rear wheels break loose too easy due to the progressive throttle in those settings.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 09-08-2023, 09:10 PM   #5
pontiaco1
Drives: 2018 1LE
Cool, I just tough I need more sway bars and or springs would help !!
Old 09-09-2023, 05:52 PM   #6
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
I added a hotchkiss front bar to mine only in that I run square Nankang tires and didn’t want to fight the rear end looseness in autocross. That bar set soft and -2.8 camber gets me good use of the inner tread block. With stock bars I used only about 2/3 of the inner block. Car stays flatter, but still has some , better turn in and no power down on exits
VR Baron is offline   Reply With Quote
