Old 09-08-2023, 01:02 PM   #1
overdriv
overdriv's Avatar
Drives: 1969 Chevelle SS 2019 2SS Camaro
Help needed!!
My grandson is going to school in Bloomington/Normal, IL. He called me last evening, says his car is overheating. He knows very little about cars. He has a 2013 Ford Focus 4cyl. auto.
I had him check the usual things over the phone.
He says;
Belt is there
overflow tank is empty
no fluid on the ground
motor starts and runs good
He did not know whether the fans were running or if they ever had run??
Not looking for any diagnostics here just mentioning this so you know what I/he is up too.
Anyway, hoping someone local to the area, could tell me a good shop for him to take it to that is trustworthy.
Thanks in advance
overdriv is offline   Reply With Quote
Old 09-08-2023, 01:06 PM   #2
1COR.1:18
Whosoever Will
1COR.1:18's Avatar
Drives: 2010 1LT Victory Red
Tell him to sell that Ford and buy a Chevy.
1COR.1:18 is offline   Reply With Quote
Old 09-08-2023, 01:42 PM   #3
overdriv
overdriv's Avatar
Why say, what a helpful post.
Old 09-08-2023, 01:51 PM   #4
1fastz28
Drives: 2022 2SS 1LE
He says;
Belt is there
Thanks in advance
might be a bad thermostat.
1fastz28 is offline   Reply With Quote
Old 09-08-2023, 02:10 PM   #5
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Overflow tank should not be empty. fill to the cold line until it stays there. Good luck
Old 09-08-2023, 02:14 PM   #6
h422694
h422694's Avatar
Drives: '16 Z06 7 Spd, 2024 High Country HD
I would check radiator while engine is cold and then makes sure it is full and fill overflow to correct level. Start car and let run for 10 min of so and watch temp guage. Let sit to cool and check for leaks around all hoses and connections, overflow tank, and radiator. FYI - overflow tanks can get small cracks that open when hot and close when cold so check for moisture on sides and bottom. Then I would check temp \\\\thermostat as someone else indicatd,
If he is ever driving it and it gets hot set heater temp to hot and turn on fan to high. Helps disipate heat.
h422694 is offline   Reply With Quote
Old 09-08-2023, 05:20 PM   #7
SwL_Wildcat
SwL_Wildcat's Avatar
Drives: 2024 ZL1
What is the oil level at? Is there milky grey sludge when you look in the fill cap? That coolant has to be going somewhere.
SwL_Wildcat is offline   Reply With Quote
Old 09-08-2023, 05:40 PM   #8
bsn
Drives: 2013 ZL1
The OP is looking for someplace for his son to take his car to, since nobody chimed in I would suggest having him find a traditional parts store like a NAPA or Car Quest and ask them for a recommendation for a competent and honest shop. They deal with them daily and know who is good and who to stay away from.
bsn is offline   Reply With Quote
Old 09-10-2023, 10:36 AM   #9
90503
90503's Avatar
Yes, he's looking for somewhere to take it, but there's no good reason he can't add coolant in the meantime.
Old 09-10-2023, 11:23 AM   #10
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Fill overflow tank immediately,before it burns headgasket.
chevy pilot is offline   Reply With Quote
Old 09-10-2023, 11:24 AM   #11
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Yes and yes.
0stones0 is offline   Reply With Quote
