Old 09-03-2023, 04:26 PM   #1
BeauRichardson
Drives: 2019 Chevrolet Camaro SS
Build update!
Just ordered some of what i would call the finishing parts as far as power wise goes. Finally going to be finishing up the secondary port injection system. I also finally got myself a proper catch can.
Going with full fragola -8 a fittings and fuel line for everything, and also bit the bullet and went ahead and purchased the griptec 3.5 pulley for the procharger. Right now i’m making about 11-13 psi on the 3.85
After all this is installed we will be hooking up the Reflex+ module and we will start figuring out the fueling for the secondary port injection. Also i might add, i didn’t go with the port plates. I have a holley low ram with fuel rails, so i just purchased the control module and the injectors.
Once all of this is done i will be back on full e85. and not sure how much boost i will make but i would like to shoot for at least 18 psi. Not sure how much power all of this will equate to, but the current butt dyno says about 800 give or take on pump 91 and 11-13 Psi
'19 Camaro SS | LT4 High Side and LT4 injectors | Fore Innovations Triple 525 In-tank pumps | Too High PSI Secondary Port injection | E85 | Holley Low Ram | BTR Stage 3 S/C Cam | Circle D 3600 Stall | Forged pistons and rods | D1X procharger, 3.5 pulley making 18-20 PSI
BeauRichardson is offline   Reply With Quote
Old 09-03-2023, 08:29 PM   #2
laynlo15
Drives: 2022 Lt1 A10
You'll love the THPSI PI and Reflex, I've been running mine about a year now with not one issue, freaking awesome for sure. You should have plenty of fuel to run E65, nice build.
Old 09-04-2023, 03:44 AM   #3
BeauRichardson
thank you very much my friend! and i am hoping we can push it to full e85 pump so i don’t have to mix like i used to haha
Old 09-04-2023, 07:04 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
That combo should be able to rock and roll!
