![]() Drives: 2018 ZL1 1LE Join Date: Nov 2021
Schroth Profi II ASM four point harness system with sub straps to convert to 6 point
I am selling a Schroth Profi II ASM 4 point harness with a sub strap harness to convert this to a 6 point harness.
The Profi II ASM is designed to be used as a four point system. For this reason it is perfect for use in Driver Education cars or any other application where stock seats are retained. The Profi II ASM incorporates Schroth's legendary ASM (Anti-SubMarining) technology that is the only thing like it on the market. ASM is an extra fold of material sewn into the right shoulder belt that elongates at a different rate than the outboard belt. This allows your upper torso to twist slightly. On the rebound phase, your torso is planted firmly back in the seat rather than allowed to slide under the lap belt. The Profi II ASM shoulder is only available in 3" width but is still suitable for use with a Forward Neck Restraint such as a HANS device and included is a dual sub strap to make this belt into a 6 point at any time. As you can see on the box that the expiration date is 2023 but if are not professionaly racing I would not think that should really matter. $200 + shipping.
2007 Shelby GT500 Vista Blue (SOLD)
2019 Shelby GT350R Magnetic Metallic (SOLD) 2018 ZL1 1LE Hyper Blue |
SOLD>>>>>
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS Join Date: Dec 2009
Were the lap belts 3”?
Orange Krush II
I believe so but they are already at UPS on their way to the buyer so I can't look.
