Old 09-03-2023, 01:42 PM   #1
Iconic
Miller Time Wisconsin
Iconic's Avatar
Drives: '24 VOM 1SS 1LE M6. 1 of 4
Location: Formerly USA, now planet of the apes bizaroworld
Latest 75W-90 gear lube
I want to do the 500/1500 mile diff lube changes on my 1SS 1LE
I'm seeing two common Dexron numbers
#1 88862624 75W- 90
#2 88862624 75W-90 GL5
Both have been posted here, some treads are years old. I thought I'd ask for the latest instead of piling onto old threads.
2024 1SS 1LE M6 rockcrusher in Vivid Orange Metallica. 1 of 4
Iconic is offline   Reply With Quote
Old 09-03-2023, 01:49 PM   #2
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
#1 with the friction modifier already added
Old 09-03-2023, 10:54 PM   #3
Iconic
Iconic's Avatar
Then which Camaro trims take #2 - 88862624 GL5?
My owners manual states "see your dealer" for gear lube part number. Being a holiday weekend and they are not open for 2 more days, I've wasted about 3 hours researching this to get nowhere.
Old 09-04-2023, 06:10 AM   #4
CalgaryZL1
CalgaryZL1's Avatar
pretty sure GL5 is synthetic formula. can’t see why you couldn’t use either one, unless there’s some sort of compatibility issue using the synthetic with non-synthetic when doing a dump and fill
Old 09-04-2023, 07:02 AM   #5
6spdhyperblue
Drives: 2SS 1LE
https://bobistheoilguy.com/forums/th...erence.328135/
Old 09-04-2023, 07:29 AM   #6
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Only 3 hrs? I had my car for 2 months now and I'm still looking for better answers
The thing that pisses me off is GM cant even pull an answer out of their ass to print the correct fluid in our newer manuals. "See dealer".....yeah OK, so some idiot can give the wrong part number out of the half dozen that's out there
Here on the forum you will be told to use NOTHING but this https://www.amazon.com/gp/product/B0...N9MTFHYL&psc=1
But I'm thinking of grabbing the Valvoline 75w90 bags to avoid the pumping/mess. I'll use the AC Delco LS additive with it. That's if I choose to go that way.
EDIT: After more research, I'm sticking with the OE fluid in the link I posted
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60'
1998 Camaro Z28 A4 - Bolt-on
1999 Camaro Z28 A4 - Stock
Dynamical is offline   Reply With Quote
Old 09-04-2023, 01:07 PM   #7
Iconic
Iconic's Avatar
According to the bobtheoilguy link, this confusion has been going on for YEARS
Old 09-04-2023, 01:12 PM   #8
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
Delco Dino with LS additive
Old 09-05-2023, 12:03 AM   #9
Daily1LE
Daily1LE's Avatar
Drives: 2018 Camaro 1SS 1LE
Attached image is everything I used when I changed diff and trans fluids. Have been through 2 changes now and 5 years / 20k miles thus far no issues.
2018 1SS 1LE - DSX E85 Kit | Full ARH Exhaust | RotoFab CAI | Katech Cam | Katech Ported Stock Heads | Tuned - 530HP/456TQ
Daily1LE is offline   Reply With Quote
Old 09-05-2023, 09:11 AM   #10
Iconic
Iconic's Avatar
^^^ Thanks Matt, my dealer confirmed the 88862624 75W-90 GL5.
Old 09-05-2023, 10:23 AM   #11
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Same part number, they just added the GL-5 identification.
'18 1SS 1LE Black, PDR
