Old 09-02-2023, 12:48 PM   #1
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Best Brake Pads for Street & Track/Road Course?
Are there any pads out there that have sufficient performance for both daily driving as well as track or road course use? I'm not really looking for a 'low dust' pad, but would like to keep dust 'manageable' if that makes sense. I am more concerned about braking performance while also retaining ordinary streetability use.
I was looking at these:
https://www.knsbrakes.com/products/c...ms/series/1091
Thoughts?
Also what is the P/N for normal AC Delco or Brembo 1LE pads?
Need4Camaro is offline   Reply With Quote
Old 09-02-2023, 02:02 PM   #2
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
I had good experience with Carbotech, my Hawk 60's squeal slightly on the road but it's not bad at all. I actually only started noticing the sound after I took out my back seats to install my 4 point roll cage.
Christian1LE is offline   Reply With Quote
Old 09-04-2023, 06:52 PM   #3
cdrptrks
cdrptrks's Avatar
Stock SS 1LE pads: 84732503 rear, & 25940447 front (ACDelco # 171-1040). Amazon, RockAuto, and eBay are usually the cheapest places to buy them
The price per hour of track driving is probably higher with stock pads but they're sufficient for stock tires in my experience and you save the labor of swapping to proper track pads before each track day and swapping back after each track day. If you daily drive the car leaving track pads installed all of the time will likely significantly increase rotor wear because they're operating below their minimum temperature (in addition to being noisy). If you use better tires than stock I would not recommend the stock pads because they're likely to overheat and wear about twice as fast. With better tires, stock pads might also prevent you from using a little bit of the braking ability of the tires towards the end of sessions due to overheating.
https://www.camaro6.com/forums/showthread.php?t=475866
Old 09-05-2023, 01:12 PM   #4
23Redrocket
Drives: Chevy Blazer, Corvette, Camaro
Take a look at EBC blue stuff pads. Half the dust, easy on rotors and very track capable.
23Redrocket is offline   Reply With Quote
Old 09-05-2023, 01:30 PM   #5
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
call ken at kns he can help !
Old 09-05-2023, 02:25 PM   #6
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
The EBC Pads are a great option for street and track.
Sales@Phastek is offline   Reply With Quote
Old 09-06-2023, 03:00 PM   #7
Roostie
all it takes is cash
Roostie's Avatar
Drives: 2018 LS V6 1LE; 2000 BMW 540i 6MT
+1. I'm very happy with the street and track performance of my Blue Stuff pads.
Roostie is offline   Reply With Quote
