Old 08-31-2023, 02:11 PM   #1
CTRifecta
CTRifecta's Avatar
Drives: 2SS 1LE
Highest mileage 1LEs
Curious to see how the higher mileage 1LEs are holding up, let's see who's got the highest mileage 1LE and how reliable has it been? If you track it as well, that would be good to know too!
2024 2SS 1LE | 6MT | Riverside Blue
1100 - Order submitted - 7/12/23
2000 - Order accepted - 8/22/23
Vehicle Built (per chevy chat bot) - 10/10/23
Window sticker available online - 11/4/23
Arrived at dealership - 11/10/23
CTRifecta is offline   Reply With Quote
Old 08-31-2023, 04:00 PM   #2
t-ray
Drives: 2022 2SS 1LE
I'm personally curious how the suspension holds up over high miles.
t-ray is offline   Reply With Quote
Old 08-31-2023, 04:18 PM   #3
WhyUMad1LE
Drives: 17 SS 1LE
60k original owner miles.
1 change rotors/pads/brake fluid, 2x change transmission & diff fluid (1st was when car was new). Oil change every 5-7k. Clutch and suspension seem fine.
At the dealer right now for a “Service Stabilitrak”/“Service Power Steering” issue.
Old 08-31-2023, 04:43 PM   #4
Briland_1LE
Briland_1LE's Avatar
Drives: 2020 Camaro SS 1LE
Mine is a 2020 with 50k miles. Hadn't had a problem yet and I track it a lot on top of the daily driving.
Briland_1LE is offline   Reply With Quote
Old 09-01-2023, 04:13 PM   #5
1jaaay
1jaaay's Avatar
Drives: 2019 Camaro 2SS 1LE
2019 with 30K miles.
2019 Camaro 2SS 1LE M6
Satin Steel Metallic
Instagram: @nightfury1le
1jaaay is offline   Reply With Quote
Old 09-02-2023, 09:23 AM   #6
ColeD
ColeD's Avatar
Drives: Chevy Camaro
2022 with 30k.
DRIVE THAT THING
'22 2SS 1LE manual in Red Hot with Red seat belts, rotofab intake, catch can and everything amsoil.
ColeD is offline   Reply With Quote
Old 09-04-2023, 06:11 PM   #7
R1LEY
R1LEY's Avatar
Drives: 2018 Hyper Blue Camaro 1SS 1LE
2018 SS 1LE, single owner with ~71k miles. Tracked it a few times and have kept up with all of the maintenance based on the manual, doing oil changes whenever the oil life monitor reaches 20%. E85 tune, rotofab and lt2 intake installed at 55k miles. Just recently had a very slight leak from the oil pan due to a loose bolt, and had to replace a front wheel bearing at 60k. Other than that it’s been a solid, trouble-free vehicle that I daily drove up until this spring, and now I have a second vehicle for bad weather and the winter this year.
R1LEY is offline   Reply With Quote
Old 09-05-2023, 07:43 AM   #8
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
+66k miles.
Oil every 4000+/- miles or about 50% life.
Diff and trans fluid every 12k or once a year in the spring.
4th set of tires.
Original brakes.
No track time.
R/F strut starting to seep a little, not wet just some sweat right now.
Paint in front of rear wheels sandblasted.
'18 1SS 1LE Black, PDR
