![]() Drives: 2021 Camaro 1SS Join Date: May 2021
Outside Temp REALLY low?
OK, I have searched the form for this answer, I have seen older threads about no display and 1 about reading high. Not my issue, I get in the car yesterday, I get the "caution ice may be present" message. But it's 65 degrees outside, I look at the temp on the dash and it reads -39? I drive around a while and go about my day. After 20 mins it starts climbing back to the actual temp. This morning it reads 32 climbs to 42 then in the fast food driveway drops to -19. Has anyone had this happen?
Car is a 2021 1SS |
#2 | |
![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
#3 | |
Yes it does. I was thinking that was the most likely cause. |
-39 is the low limit.
Your ambient temp sensor likely failed open, which will result in it reporting the lowest temp. Unfortunately, many systems require good data from this sensor. DIAGNOSTIC INFORMATION AND PROCEDURES > DTC P0071-P0074: AMBIENT AIR TEMPERATURE SENSOR > CIRCUIT/SYSTEM DESCRIPTION The ambient air temperature sensor is located behind the grille. The engine control module (ECM) monitors the ambient air temperature sensor utilizing a low reference circuit and signal circuit. The ECM monitors the voltage drop across the sensor, which is inversely proportional to temperature. When the ambient air temperature is cold, the resistance of the sensor is high. When the ambient air temperature is warm, the resistance of the sensor is low. The ECM converts the voltage value to a temperature value. The ECM also sends the temperature value to other control modules via serial data. |
#5 | |
Thanks for the info. Looks like the dealer will be getting the car soon enough. |
