08-20-2023, 09:28 PM | #1 |
Drives: 2022 camaro SS 1LE Join Date: Jan 2023
Cylinder head question
Ok guys im running a set of stock ported heads currently an they are doing great but with that in mind i have been thinking of changing to a better quality head. The 3 choices are
Set of CID heads, a set of PRC LTX, an these mast https://www.mastmotorsports.com/coll...ad-medbore-cnc heads all are high quality and come with better valves, seals, valve seats, guides, both are very similar in their flow numbers. This is on a daily driver with a mild cam making currently over 560 at the wheels, fbo. Would love to hear thoughts, experiences, reviews, and opinions. I dont mind tearing it down, just wondering what anyones experiences have been if they have switched from a ported to aftermarket head. Last edited by CJZ-SS1LE; 08-21-2023 at 11:00 AM. |
08-20-2023, 10:49 PM | #2 |
Drives: like an old lady Join Date: Jun 2012
the only thing i can add: i closely followed btr's testing with their 220/225/230 camshafts. results are from their engine dyno. looks like the cid was worth 40 crank over a set of ported gmpp heads at an already elevated power output. the independent testing i've seen of msd vs trinity says if na under 8k rpm, they produce about the same hp with trinity losing tq everywhere. i think a safe prediction is that a quality ported msd will make 20+ more crank vs unported.
220 stock heads msd 607 540 225 stock heads msd 608 528 225 gmpp heads msd 649 555 230 gmpp heads msd 680 570 (mill/fly cut) 230 gmpp heads trinity 691 545 (mill/fly cut) 230 cid heads trinity 733 574 (mill/fly cut)
08-30-2023, 04:17 PM | #3 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
I really want to see the 220 with heads. Seems that is always skipped in testing
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
