![]() Drives: 2017 Hot Red 2ss Auto adrenaline Join Date: Aug 2017
Rear end groan after oil change on ELSD???
Did my diff fluid change after 1500 on my 1le and used the Valvoline options.
It ended up giving the first turn of the morning groan that didnt have it before. I waited awhile for it to completely empty and didnt over fill. anyone have thoughts? |
![]() ![]() ![]() ![]() ![]() Drives: 2012 Shelby GT500 Join Date: Jan 2020
Drain again and ONLY use the ac delcon GM stuff.
2012 Shelby GT500 with VMP Gen 3R.
Prior: 2023 Camaro 2SS 1LE 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
Without knowing the exact Valvoline product and the friction modifiers present, it is hard to know if what you used is compatible.
it is the friction modifiers which allow the plates to slip smoothy while turning. So, yep, sticking with AC Delco probably safest. |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
As stated, drain it and fill it with AC Delco fluid with the correct additives
![]() Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
Let us know after you do it and if the noise goes away. Good luck
![]() Does anyone know the exact up to date part number for the AC Delco?
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
#7 | |
![]() Drives: 18' 2SS 1LE, 94' Z28 Join Date: Apr 2010
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2018 Camaro 2SS 1LE - 1,xxxHP
D-1XH Procharged, LME 416, GPI/CID Track Attack Heads, BTR top end, Katech oil pump, Pray Tuned, Stainless Works, Anderson Composites, 13GFab, BC Forged & More 1994 Camaro Z28 - 7xxHP Nitrous Outlet Direct Port Nitrous & more, Creator of AggreSSive spoiler, Multi Magazine Featured Camaro Z28 in GMHTP, Super Chevy, Nitto, and Camaro Performers |
#8 | |
Does the ELSD take a different fluid than the MLSD? I'm looking at 3-4 different part numbers on this fluid which I cannot decipher the difference ![]() https://www.amazon.com/Genuine-88900.../dp/B00BK7LXGM https://www.amazon.com/ACDelco-10-41.../dp/B07CL6MBX5 https://www.amazon.com/ACDelco-10-40.../dp/B000QGOX1A https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 GM does a great job with giving me a headache
#9 | |
![]() Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
#10 |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
Don’t dick around with the rear end only run the Dexron LS period! And if you plan on keeping your car for a long time do it annually, it’s cheap insurance.
#11 | |
#12 | |
Shadow Gray '19 ZLE M6
ACDelco 10-4034 (GM 88862624 in US, 88862625 in CA) is for our cars. ACDelco 10-4016 is what my 4th gen trans am takes. The information is in the owner's manual. Page 329 in the 2019 manual. Might be a different page for different model year.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 LT1 10 speed auto Join Date: May 2013
Drain some oil out and add the same amount back of the friction modifyer. I changed my rear end oil with the mobile 1 product that has the friction modifiers in it, but had to add a half tube of the friction modifier to stop the groan. Its been gone for 15k miles.
#14 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Please explain why.
Ive used Mobil 1 and Valvoline (most often due to it's slightly better VI) for 30k miles in my 1LE and it's seen many drain/fills and hard track use. I guess it's a ticking time bomb. It's easy to blame the gear oil here, as that's the only one (1) thing mentioned, but no one here has heard the OP's actual noise or put eyes on the vehicle, yet you all are jumping to a definite conclusion. |
