Old 08-11-2023, 10:50 PM   #1
2023ZL1RapidBlue
Drives: ZL1, S2000
How to get launch control to hold RPM's-M6
Hello,
I searched on the net and on here but no real info.
I do get the launch control to enable on my 2023 M6 but RPM's don't hold.
What's the trick? I do have my seat belt on and in 1st gear.
I read that older vehicles used to say "Press Brakes" or something like that. The newer ones don't sayanything. I've tried several times and the RPM's just don't hold. Is there a trick with the accelerator?
2023ZL1RapidBlue is offline   Reply With Quote
Old 08-12-2023, 06:43 AM   #2
Rapid_blue_zl1_22
See you at the Track!
Rapid_blue_zl1_22's Avatar
Drives: 2022 Rapid Blue SS 1LE
Originally Posted by 2023ZL1RapidBlue View Post
Hello,
Are you going into PTM Sport 1/2, or race before going through the launch control menu?
Here is a tutorial on how to do it:
https://youtu.be/RFyf_5Qqvik
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD)
Rapid_blue_zl1_22 is offline   Reply With Quote
Old 08-12-2023, 09:10 AM   #3
2023ZL1RapidBlue
Drives: ZL1, S2000
I'm doing launch control menu first, then, double tapping the traction control button, then going into PTM Race. Hmmm, is that why?
Although, i believe I tried launch control menu last a few times and still.
Thanks, let me watch that vid, thanks again.
Old 08-12-2023, 11:09 AM   #4
Stroker548
Stroker548's Avatar
Drives: 2019 ZL1 1LE
I know that the wheel has to be straight and thethrottle has to be decked quick. Dont *****foot around and roll into it. Straight to the floor.
Stroker548 is offline   Reply With Quote
Old 08-12-2023, 11:09 AM   #5
Rapid_blue_zl1_22
No problem, hope it helps
Old 08-13-2023, 08:11 AM   #6
2023ZL1RapidBlue
Drives: ZL1, S2000
Hmm, perhaps the throttle is the problem. That's the only thing I'm not sure I've done. Wheel is def straight.
Now, does the Launch control menu have to stay showing ? I have left it showing anyway but curious now. Or once you set your RPM and target, can you show a diff menu like the oil gauge as an example?
Old 08-13-2023, 11:10 PM   #7
2023ZL1RapidBlue
Drives: ZL1, S2000
I got it to work. I was being a p*ssy with the throttle.��
Gotta smash it down.
Learned a few things as a new owner. Launch control and line lock don't work in Sport Mode, only Track mode. Also, don't have to have your seat belt on. �� Thought I read somewhere on the net that you do.
Old 08-14-2023, 01:17 PM   #8
Stroker548
Stroker548's Avatar
Learned a few things as a new owner. Launch control and like lock don't work in Sport Mode, only Track mode. Also, don't have to have your seat belt on. �� Thought I read somewhere on the net that you do.
Nice.
Old 08-14-2023, 10:18 PM   #9
2023ZL1RapidBlue
Drives: ZL1, S2000
Nice.
I most certainly took your advice as well. Smash the darn throttle.
