Old 08-11-2023, 11:50 AM   #1
Drnick
Drives: 22’ ZL1
Mobil 1 supercar oil?
I’m assuming Mobil 1 supercar oil 0W40 is just
A re-brand of there 0W40 Dexos 2? Is that a safe
Assumption??? Or is there an actual difference
Between the two?
Drnick is offline   Reply With Quote
Old 08-11-2023, 12:14 PM   #2
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Between the two?
This was also questioned over here: Basically same oil different packaging.
https://www.corvetteforum.com/forums...-supercar.html
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
2023_ZL1-AUTO is online now   Reply With Quote
