Old 08-10-2023, 09:07 PM   #1
Burntblues
Drives: 2017 ZL1: 1989 Camaro
LT1 supercharger upgrade tune question
Hey everyone,
I just finished installing my ZL1 supercharger on a friend's 2SS using a kit he ordered online. We're up and running but are looking for help on 2 issues.
First, I'm getting trouble codes P00EB, P2228, and P227C (it leads me to think there's an issue in the breakout harness or the MAP sensor that got installed is bad), but am I missing something on that front? Is there a learn procedure I don't know about?
Second, what about a tune? I flashed it with me stock ZL1 tune and it starts and runs nicely in the shop but I'm told I can't run that tune or it'll damage the engine. Obviously we haven't pushed it yet since I'm still in "reduced power" mode due to the above codes but could anyone assist on that? Anyone have a tune file they can share that would work? It's a stock 2SS manual. We don't have any tuners near us for adjustment and I'll admit that's beyond my skill level.
Thanks!
Burntblues is offline   Reply With Quote
Old 08-10-2023, 10:17 PM   #2
Is remote tuning an option? This is an everyday scenario for a pro, and you guys trying it for the first time, guinea pigging your friend's "baby", is pretty risky. There are several tuners on this forum who do remote tuning, but of course it's to be worked out between you and them for a customer installed setup.
Old 08-10-2023, 11:10 PM   #3
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
There are alot of differences in a stock zl1 tune based on the hardware it's fitted with, specifically injectors and high pressure fuel pump, along with a difference in compression. I personally would put the original stock tune back on it. It will run alot better and fine if you're just in the shop. It will become an issue when you start getting into boost. That's also assuming you have the stock map sensor in it still. KingLT1 is the most active tuner on here in my opinion and might be able to help you out or Ted Jannetty of Jannetty racing would be another good choice that is on here.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
Old 08-11-2023, 07:41 AM   #4
cjperformance
cjperformance's Avatar
Not an expert, but I also dont think you can just flash one car's tune over another. You would normally take the original car's tune and copy values from one to the other.
My understanding is that there are things specifically coded to vin numbers and such that could brick the electronics if doing this.
Best to get a remote tune for starters and dial it in from there if you like.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
