08-10-2023, 08:28 AM | #1 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
oil in the intake tube
Does anyone else get oil in their intake tube from the fresh air inlet form the passenger side valve cover to the intake tube on a cold air inductions CAI? If so how did you stop it?
I've tried to get it to stop by putting on this oil filter from earl's but it still gets in there somehow.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
08-10-2023, 09:06 AM | #2 |
Catch Can
08-10-2023, 09:29 AM | #3 |
I have a mishimoto catch can
08-10-2023, 09:37 AM | #4 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
08-10-2023, 09:55 AM | #5 |
Maybe something like the Mighty Mouse Wild setup that does a different routing
https://docs.google.com/document/d/1...JTcepoubI/edit |
08-10-2023, 10:04 AM | #6 |
Yeah that's what I was thinking about but hate to spend another $300 + dollars on a new set up. That's the only thing I can think of that would filter the clean side of the pcv system.
08-10-2023, 10:05 AM | #7 | |
08-10-2023, 10:52 AM | #8 |
I get that as well from my K&N system. Not all the time though. I know it is coming from that valve cover because if I disconnect the line from my CAI and just leave it laying along my valve cover/manifold it doesn't get in there, plus nothing comes out of the tube end to get on my valve covers. I don't know either. And I do have an RX catch can that does its job.
08-10-2023, 12:05 PM | #9 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
I had a mishimoto catch can, and a cold air inductions cold air intake. It was bone dry when I pulled the intake tube off. And I had it routed to my stock valve covers and then to my holley valve covers when I switched to those.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
08-10-2023, 04:56 PM | #10 |
But I have extra big piston ring gaps for my boost later on. 25/27
08-11-2023, 06:28 AM | #11 | |
Anthony S
Also I just noticed that your catch can is not routed as intended. The mishimoto is supposed to have the inlet from the manifold and the outlet to the valley cover. It looks like yours in Tee'd into the valve cover port. Not sure if that makes a difference, I'm just pointing it out.
08-11-2023, 07:28 AM | #12 |
Yeah I've been talking to a guy at mighty mouse and I told him that I want to do it all (drag race, road race, and more) and he recommended thier mild can with the recirculating top. And then I told him my problem with the oil in the intake tube. So he said there's a modification that can be done to the can that will allow more to flow through the can to reduce the positive crank pressure but told me that the modification would have to be done by me giving no instructions on how to even do it. So that was the end of that conversation.
08-11-2023, 07:37 AM | #13 | |
08-11-2023, 08:13 AM | #14 |
GPI Sales Consultant
Your catch can setup only flows under vacuum - which you don't have at wide open throttle. That line is for venting crank case pressure, which with big ring gaps I'm sure you get a bunch of.
There are a few solutions, but I would get an Elite Engineering clean side separator. You'll cap the valve cover, and move the line to the clean side separator, which replaces the oil fill cap with a small air oil separator with a check valve so that it only flows when you've got pressure. The oil drains right back into the valve cover, rather than venting to your intake. Eventually, if you're adding boost, you'll need to rework your crankcase vent system in a more comprehensive way to handle the additional flow you'll see, and a vented can would make sense.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
