Old 08-09-2023, 09:24 AM   #1
Fun
Fun's Avatar
Drives: 2020 V6 Auto 3LT RS
Key FOB Battery Replacement gone wrong
I’ve never had a problem before but I messed up trying to change key fob battery. Can anyone show me where the spring and other piece go or is it ruined?
Thanks very much
Fun is offline   Reply With Quote
Old 08-09-2023, 09:30 AM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Like this:
Old 08-09-2023, 09:49 AM   #3
Fun
Fun's Avatar
Is the part and the spring supposed to lay inside the slot tightly. I have a broken thumb and am struggling
I have a 2020 if it makes a difference.
Old 08-09-2023, 10:16 AM   #4
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
Take the spring and put it against the plastic fob molding. Take the chrome piece and place it against the opposite side of the spring. Put the other side of the fob back over it and snap it back together.
jamala00 is offline   Reply With Quote
Old 08-09-2023, 10:42 AM   #5
Hostile_1LE
Hostile_1LE's Avatar
Drives: 2020 Camaro SS 1LE | Satin Steel
I need to do this too. are the two halves of the key glued together or just press fit together. in other words, do i need to glue the two halves or will they stay put when I put the key back together?
HCI | GPI SS3 | E85 | xxx whp \ xxx tq
Hostile_1LE is offline   Reply With Quote
Old 08-09-2023, 10:45 AM   #6
jamala00
jamala00's Avatar
They are press fit
Old 08-09-2023, 11:45 AM   #7
Supr4n3
Drives: amg s63, ram TRX
I'm happy to report that I snorkeled for 2 hours with the key fob for my Camaro rental in my swim shorts in Hawaii and the fob continued to work for the duration of the rental.
Supr4n3 is offline   Reply With Quote
Old 08-09-2023, 12:15 PM   #8
Fun
Fun's Avatar
Please help me clarify, see pic. THANKS
Old 08-09-2023, 01:09 PM   #9
jamala00
jamala00's Avatar
The left side... Are you seeing the other posts of the pics posted and even the one I posted with the arrows?
Old 08-09-2023, 01:12 PM   #10
Fun
Fun's Avatar
Thanks I’m at work might have missed post.Thanks again.
Old 08-09-2023, 01:17 PM   #11
jamala00
jamala00's Avatar
No Worries... Those pics should give you everything you need to put it back together. Good Luck
Old 08-09-2023, 05:32 PM   #12
Fun
Fun's Avatar
I’m finally home from work. I’m having trouble because my thumb is broke. Do I put the spring on the part before I put the part in, or do I lay the spring in the channel before I put the part in 🥵Thanks again.
Old 08-09-2023, 06:33 PM   #13
Anjilslaire
Anjilslaire's Avatar
Drives: 2021 3LT RS A10
As Jamala00 said
"Take the spring and put it against the plastic fob molding. Take the chrome piece and place it against the opposite side of the spring. Put the other side of the fob back over it and snap it back together."
Anjilslaire is offline   Reply With Quote
Old 08-10-2023, 04:37 PM   #14
Fun
Fun's Avatar
I appreciate all the help and want to apologize, but I can’t get it together. I have the spring in the correct place I think, but I can’t get the chrome piece where it belongs. Is it supposed to just lay on top or go in the channel some how? Pr is it supposed to fit tight in the channel? I couldn’t figure it out even with the spring out. It’s not my broken thumb at this point, it’s my ignorance.
Any suggestions appreciated. I hate to give up and go to the dealer (stealer)
Thanks again..
