Old 08-07-2023, 12:05 PM   #1
Laika
Laika's Avatar
Drives: 2018 Camaro SS 1LE
Common Loose Bolts 2018 SS 1LE?
Hi everyone. I was wondering what bolts on 2018 cars people have found to come loose from the factory. I'm putting the car on the lift soon to fix an oil leak which I suspect is from oil pan bolts being loose and would like to check the torque on other problematic bolts if there are any. Currently planning on checking the oil pan bolts and oil cooler bolts. Thanks!
Laika is offline   Reply With Quote
Old 08-07-2023, 01:19 PM   #2
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Oil pan was the only loose bolts that I had. Cleared up that little oil leak.
Old 08-07-2023, 02:00 PM   #3
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
How long did it take before it started leaking? My LT1 has almost 3k miles on it, just bought it. No leaks yet. Guess this will go on my to do list.
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 08-07-2023, 03:24 PM   #4
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
I know the early years of the 6th gen they had to put out TSB’s regarding axle bolts backing out and the sway bar end link bolts. Usually they’re all fixed by now though
2016 1LT v6
- Totaled
Happiness: Infinite
Old 08-07-2023, 04:37 PM   #5
Trochoidal
Drives: 2017 Camaro 2SS A8
I’d suggest you also check the 4 oil cooler bolts on the drivers side of the oil pan.
Old 08-07-2023, 04:55 PM   #6
Canyonero
Canyonero's Avatar
Drives: F-Series Canyonero
My swaybar endlinks were finger tight.
Canyonero is offline   Reply With Quote
Old 08-08-2023, 09:56 AM   #7
Laika
Laika's Avatar
Thanks everyone for all the responses, will check all the things mentioned and report back on what I find.
Dynamical - my car has 38k miles on it and must have started leaking within the last 3k miles as I would have noticed it during my last oil change
