Old 08-03-2023, 05:40 PM   #1
Johnny Camaro
Drives: 13 ZL1vert,19 ZL1 vert A10 10/24/18
Front Brake / Rotor issues
Hi my 19 ZL1 with 50.000 needes new rotors and I looked up some threads and lot of people said " don't buy the slotted/vented ones bc OEM are really great.
And bc I have a vert I didn't buy it for track days, so I thought if the OEM is good for guys that sometimes track them they've to be good for me too right?
I checked out some YT vids and saw that some guys put OEM rotors on and had the art numbers below their vids.
So I copied those numbers and what I got was AC Delco ones and correct me when I'm wrong but I checked out the Brembo website and the numbers were the same if I can recall.
Then when they came in the have a real weird grey coating on them and I thought that will go away with my new Powerstop ceramic brake pads.
So 500 miles later they still look dull and not shiny as normal rotors would look like and on top of that they car is shaking with hard breaking form 65+ miles.
So do anyone of you guys bought the same ones and tell me your experience please.
Johnny Camaro is offline   Reply With Quote
Old 08-03-2023, 10:10 PM   #2
Vigilante375
Drives: 2018 Camaro ZL1
Yes. New rotors have a grey coating on them that is meant for anti corrosion. It is supposed to go away once after a while. Just give it some more time.
I replaced my rears last year and the coating did go away after a while but I wasn't paying attention for how long it took.
Old 08-03-2023, 10:30 PM   #3
Did you burnish the brakes after replacing the rotors and pads? If not, it's not too late to do it now.
Old 08-04-2023, 01:09 PM   #4
Johnny Camaro
I see now that's more important then I thought it would be :(
Old 08-04-2023, 01:11 PM   #5
Johnny Camaro
I do need to move to a bigger city or go into the country to get those long miles of stretchy roads lol
Old 08-04-2023, 02:18 PM   #6
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
You probably have some buildup on the rotors that is what’s causing the shaking
Old 08-04-2023, 02:21 PM   #7
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Just a little open road, just run it hard to 60 and get on the brakes hard but no ABS if you can help it and not to a complete stop. Take it back to about 15 or 20mph and let it roll out a bit. Repeat. Like Arpads attachment. I have a frontage road close by on the undeveloped side of the interstate that works well.
Old 08-04-2023, 06:11 PM   #8
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Why did you get Powerstop brake pads? Is it a brake dust thing? I always use OEM pads, they can be bought on Amazon for $300 a full set F + R and they are some of the best in the world... the combination of ZL1 calipers, ZL1 rotors and SRF fluid with OEM pads is all you need to set the fastest laps on the most demanding tracks--I'm talking HPDE use not real racing, not endurance. Other pads like DS 1.11 are better (I love DS 1.11 my favorite), but they cost 3-4x a set of OEM ZL1 pads. DS 1.11 does last 3x as long so it basically offsets.
As far as dust, I can't see myself sacrificing some of the best stopping power of any sports car in the world for having less dust, just hit them with a hose and soap and a brush and most of it comes right off, 5-10 min to do this dry it with leaf blower.
SFV1LE is offline   Reply With Quote
Old 08-04-2023, 06:21 PM   #9
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
If it were me I would use the OEM parts for the ZL1. May cost more but worth it in my honest opinion.
Old 08-18-2023, 03:31 PM   #10
Johnny Camaro
Yeah it was for the brake dust bc I DD the crap out of it
See my topic with the most milage on a ZL1 19+ ..mine 50.000 already.
Old 08-18-2023, 03:42 PM   #11
CalgaryZL1
CalgaryZL1's Avatar
I changed mine after 1000 km because I was sick of the dust! The braking power is very compatible for me but I’m also not on a race track. I got the rotors I got the calipers, so I am willing to take a loss on the pads
Old 08-18-2023, 08:25 PM   #12
Vigilante375
Most mileage on a ZL1 is over 215k miles, no mods. That was a 2017 and the owner never had any issues. They used the OEM parts when something was in need of replacing too.
Old 08-18-2023, 10:22 PM   #13
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
Some thoughts:
1. OEM rotors are great. Another option are DBA rotor rings from KNS Brakes
2. The AC Delco rotors are the same as OEM rotors
3. You should always clean new rotors with brake cleaner (unless zinc coated)
4. Definitely bed your pads following the correct procedure (Arpad shared above)
5. If you think there may be pad deposits on your rotors, grab a brake rotor hone to clean them up
YouTube
