Old 08-02-2023, 01:27 AM   #1
mcbat8
Drives: 2022 SS 1LE
fighting a little bit of understeer in mid corner
Car turns in well under trail braking but will have mild understeer in mid corner for long sweeper. Any suggestion what mod to help dial out the understeer?
video example:
https://youtu.be/o8z1c_OktuU?t=644
2022 SS 1LE
Mods:
stock powertrain and weight
Apex - VS-5RS 19x11 and 19x12 with used ZL1 1LE tires (2018 vintage)
Vorshlag- Front camber plate. -3.3f and -2.2r camber. 0 front toe, +0.1 total rear toe.
SPL - Rear Upper Arms and Rear Toe Links
Carbotech XP20 front pads and oem ZL1 rear pads
Endless RF-650 brake fluid
2022 White SS 1LE - stock power
Track Videos
mcbat8 is offline   Reply With Quote
Old 08-02-2023, 08:29 AM   #2
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
I think the car will always have some understeer if you're asking it to do more than it can or you're not allowing it to rotate enough before getting on the power. You have some options
Run a square setup
Turn all TC and stability control off to help turn the car with the pedals
Start adding proper aero to the front
Stiffen the rear even more.
Christian1LE is offline   Reply With Quote
Old 08-02-2023, 09:04 AM   #3
VaporPressure
Drives: '18 ZL1 1LE
Are the tires ok? I drive a zle but so far the only time I have had bad mid-corner understeer is when the inner shoulders were cording (or when I get on the gas too early, but that doesn't seem to be the case in your example). I run -3.0 camber so it seems like you have plenty of camber. You could stiffen the rear bar (is it adjustable on SS1LE?). Elsewhere in your lap it seems like occasionally you load up the steering into some of the tighter turns a little aggressively...maybe this is contributing to tires getting overheated/high pressures toward the later parts of the session? But if tires are in good shape and you're having issues even in the beginning of the session, I don't think I have a good answer for you. Nice driving!
VaporPressure is offline   Reply With Quote
Old 08-02-2023, 10:01 AM   #4
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
Anytime you add throttle and add/maintain steering wheel angle, you are setting yourself up for understeer. IMO, your overall entry speed could be improved by using the brakes longer into many of the corners, which will help point the car and accelerate being able to to take away steering wheel angle. Overall lines are pretty good, other than focusing on having the car pointed for the exit.
Ken
khcoaching is offline   Reply With Quote
Old 08-02-2023, 12:40 PM   #5
Briland_1LE
Briland_1LE's Avatar
Drives: 2020 Camaro SS 1LE
Seems like some corners you were fighting understeer some you were fighting oversteer. I don't think theres an obvious fix other than any corners your having understeer in experiment with a slightly different line or transition etc.
Briland_1LE is offline   Reply With Quote
Old 08-02-2023, 05:50 PM   #6
mcbat8
Drives: 2022 SS 1LE
Run a square setup
Is the ZL1 1LE rear swaybar stiffer? I am thinking that's where I can start.
I am using Race mode which I believe have only TC and no stability control.
Track Videos
Old 08-02-2023, 05:52 PM   #7
mcbat8
Drives: 2022 SS 1LE
yeah, 2nd track day with the car so still learning. Corner exit oversteer is expected. I mainly want to improve corner entry and mid corner to slightly more oversteer instead of understeer at the limit.
Track Videos
Old 08-02-2023, 05:55 PM   #8
mcbat8
Drives: 2022 SS 1LE
You have some good point. Car felt a lot better in the 1st session in the morning but I think as the day went on, the left front tire got punished to a point where it starts to push. I'll take the wheels off and check them.
Track Videos
Old 08-02-2023, 05:59 PM   #9
mcbat8
Drives: 2022 SS 1LE
Ken
Thanks for the input, my previous track car was a 22 BRZ so I am still adjusting going from momentum car to higher HP car. Right it seems like I am scrubbing the front tires a lot more than the rear and that's why I am looking for some setup adjustments.
Track Videos
Old 08-03-2023, 12:16 AM   #10
mcbat8
Drives: 2022 SS 1LE
I guess I found the reason why I was understeering lol. Pictured are front tires, right side is passenger and left is driver.
I was surprised to see this since the tires only have 2 track days on them. Although I did buy them used at around 4.5/32. Does this car like to eat front inside?
Track Videos
Old 08-03-2023, 08:22 AM   #11
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Toe is out of spec? Have you rechecked it?
Old 08-03-2023, 11:27 AM   #12
cdb95z28
cdb95z28's Avatar
ZL1 1LE rear bar is NOT stiffer than the SS 1LE rear bar.
"KEEP THE FAITH"-Fbodfather
Old 08-03-2023, 11:31 AM   #13
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Yup, it's near the same in it's stiffest setting.
Old 08-03-2023, 11:32 AM   #14
DaveC113
DaveC113's Avatar
Ken
Agreed.
