Old 07-28-2023, 05:52 PM   #1
ChadSZL1
Red Bull
ChadSZL1's Avatar
Drives: 2017 Chevy ZL1
Help with Pulley combo suggestions
Currently I have 2017 ZL1 with BTR stage 2 cam, 8.66 lower, stock upper, 2” long tubes, no cats, awe back, 95mm TB, standard rotor fab, JMS voltage booster, flex sensor and tuned on E60 with a trans tune also. I am adding jorkerzs full tilt port with a 2.45 upper, DSX aux pump, 103 TB, and big gulp. Car made 10.8 pounds of peek boost with the current setup. My question is should I leave the 8.66 lower with the new ported blower having a 2.45 upper, or change to the 9.17 lower/2.45 upper? It’s mainly a street car but does see the track a few times a year. This next spring I will install a trunk tank for cooling. Thoughts?
ChadSZL1 is offline   Reply With Quote
Old 07-28-2023, 06:20 PM   #2
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
A ported blower will increase boost all else being left as is. There is no sense in raising boost further when what you're doing will additionally add naturally.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
834 HP/ 840 TQ
Old 07-28-2023, 10:24 PM   #3
ChadSZL1
Red Bull
ChadSZL1's Avatar
I just want to make sure I maximize all the mods with the best pulley combo for power and not produce a crap ton of heat soak.
Old 07-29-2023, 02:37 AM   #4
ZLRob
Super Stock
ZLRob's Avatar
Well you have some space left to go. You could probably bump up another 1.2- 1.5 lbs of boost before you are outside of the blowers efficiency range and coating the engine more power to drive the blower. You want to keep the blower ratio at or right under 2.0, but you don't want to go over that at all. If you have HPTuners you can add a PID on there which will show you the current pressure ratio as you are logging.
834 HP/ 840 TQ
Old 07-29-2023, 07:30 AM   #5
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Great question, and I found myself in the same crossroad. I suggest leaving you pulleys as is, and trying to tune to maximum E content first. Once your tune and fueling is sorted, if you have room for more boost, and have some cooling mods lined up, then perhaps go to a 9.17" lower. If i was tracking the car, i'd prioritize E over boost.
Old 07-29-2023, 09:26 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
You will more than likely hit the fuel system limits if you touch the pulleys.
Old 07-29-2023, 12:42 PM   #7
ZLRob
Super Stock
ZLRob's Avatar
I agree with these guys my dude. Get the maximum amount of E content first. The primary goal is to be able to just fill up fully at the pump without having to mix. Once you have achieved that, if you have space left on the fueling THEN you can and should touch more boost.
Sometimes less on the mods is more.
834 HP/ 840 TQ
Old 07-29-2023, 05:38 PM   #8
ChadSZL1
Red Bull
ChadSZL1's Avatar
So with my 8.66 lower (10)% and the 2.45 It will be like running a 9.17 lower and stock upper correct? So close to 15% overdrive with my 38% cam lobe, jms booster and the DSX aux kit. I am good with mixing E as my gauge show live E content.
