![]() Drives: 2019 Summit White ZL1 Join Date: Mar 2020
Upper Cylinder Clean for LT Engines
So I was reading an article this morning about the LT engine.
One thing that was mentioned was that a upper clydinder clean should be performed every 10k miles. The article interfered that there was some additive or chemical clean which takes care of carbon build up on the valves. My son has a ZLE and we installed an upper pulley at 8.5k and looked into the intake side of the head and it looked pretty nasty for such a new stock car. My ZL1 now has about the same mileage. So can can someone shed some light on what is available to do a clean? |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
I you feel it’s necessary you could use this.
https://www.crcindustries.com/gdi/ |
![]() Drives: 2024 ZL1 M6 Join Date: Sep 2018
I work for BG Products and we have induction service kits for direct injection, but not on the ZL1 with positive displacement blower. Nothing will work correctly on a PD car due to the intercooler bricks knocking chemical out of suspension and blower heat making it evaporate prior to getting to the valves.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp Kooks 2 inch LT's, Stainless Works Legend NPP THP Billet Valve Covers, Mighty Mouse Wild CC Signature Forged 20x10.5/20x11.5, BMR springs, BMR Cradle lockout, AAD Billet arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
The article also mentions that the LT5 engines do not have the problem due to the fact that the secondary injectors spray directly in to the valves or on the valves? Can this be added to the LT4?
If you haven’t installed a catch can yet that Helps keep the unwanted stuff out of the engine
Yes a catch can is an option, but I have read so many conflicting posts that I am taking the info with a grain of salt. I do know that a stock ZL1 at 10k miles has a considerable carbon build up and GM must have a recommendation or procedure to help.
#7 | |
#8 | |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
BG has always been top notch. That being said, DI is a difficult cat to skin when it comes to PD cars like the LT4 or any boosted engine because of what has been mentioned above.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
834 HP/ 840 TQ |
#9 |
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
Does running E85 clean your engine after it's been running on gasoline for 10K?
I know engines running 100% E85 are very clean when they are opened up for head work. |
#10 | |
Super Stock
To answer your question, I couldn't tell you for sure, but I do run full pump E all the time now, so I know it can't hurt.
834 HP/ 840 TQ |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
#12 |
Good to know...flex fuel sensor installed and tune in progress!
#13 | |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
#14 | ||
