![]() Drives: 2023 chevrolet camaro Join Date: Jan 2023
Dash Cam and OBD II power cable?
I was wondering if this would work in my 2023 Camaro. Curious as the dash cam says 2A and the power cable says 3A.
I attached a pic of each. I already bought the camera but now want something different than the cigarette lighter due to where it is located. Any help appreciated. |
![]() Drives: 2022 2SS 1LE Join Date: Dec 2021
I haven't ever seen anything powered by ODB2 other than a AFM module, but its worth a shot to buy it and see if it powers up the camera, if it doesn't just return it. I would be concerned about draining the battery however.
I actually found one with quite a few good reviews and its only 2.1A. I'm gonna give it a try. As for the power, switch 'on' and it'll shutoff 5 min. after car is powered off. Switch 'off' and it stays on for parking surveillance and shuts off when battery is at 11.6V. Will prolly only use it in the 'on' position as the car is always parked in my garage.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Pretty sure OBD is always on
<Insert Cars You Own Here>
Yeah, think so too but the one I ordered has a shut off switch.....Hope it works....lol.
Old Gearhead
Drives: 2023 GMC Sierra Denali Ultimate Join Date: Nov 2018
Should work because GM Parts sells a dashcam powered by OBD
https://www.gmpartsoverstock.com/oem...-adas-19433434
2023 Camaro ZL1 convertible - black - SOLD
2023 GMC Sierra Denali Ultimate - black |
#7 |
Well, thats good to see, so hopefully this works also.
#8 | |
IYAOYAS
Drives: 22 1LE 2SS M6 Riverside Blue Join Date: Mar 2018
Correct about battery. I have the same setup, via obd2 dashcam and also use parking mode feature. For daily use such as to work, parking mode is not a problem, only when the car sits for more than a day without use, then the parking mode can drain the battery, or if you dont use parking mode shouldn't be a problem at all. I disconnect at the dashcam itself when im not using the car for a few days. OP, Go for it, you should be good to go with the OBD cable.
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold 2018 black Camaro 2SS M6 Redline Edition/Traded 2016 summit white Camaro RS V6 M6/Traded |
#9 |
![]() Drives: 2018 Camaro SS vert Join Date: Oct 2020
With my camaro I ran the power right to the USB in the center console but on 3 other cars at my house I have the dash cams running off OBD plugs exactly like this and they work just fine
#10 |
![]() Drives: 2016 Camaro SS Vert. Join Date: Apr 2017
Op, I purchased the same one. It did not work for me as it refused to power off the camera. I removed it and chucked it in a junk drawer. Waste of money imo.
#11 |
Contact https://www.gen5diy.com/. They make cables for dash cams and radar detectors that don’t use the OBD II port. If they don’t have one for your dash cam they can make one up for you.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions |
#12 | |
Long hauler
2016 1LT v6 - Totaled Happiness: Infinite |
#13 | |
I have have an Escort Maxcam 360c which is a radar detector and dash cam. It uses an RJ45 power connector. It is powered off of a connector on the passenger side. Wiring is hidden. Sent from my iPhone using Tapatalk
#14 |
I actually bought this one since the cable is 2.1V and the camera is 2.0V.
Here is my issue.....I just took the car for a 4 hour road trip, each way. When I have it in the 'O' position, the camera shuts off after 5-10 minutes. If I have it in the '-' position, the camera works fine and shuts off about 5 minutes after turning the car off. If you look at the description, this cable isn't supposed to do that, although, when in the '-' position, thats what I want it to do. Why does the camera shut off while driving when in the 'O' position? Faulty cable or does it have somethintg to do with the parking surveillance mode? I was also checking the battery voltage while driving and it never dropped below 12.3V at any time.....And up to 14.1V at times. |
