Old 07-23-2023, 12:10 PM   #1
Plasar
Drives: 2017 ZL1 Vert M6
Lumbar pillow for ZL1 Recaro seats
Does anyone else feel that there is a lack of lower back/lumbar support with the Recaro seats in the ZL1, 1LE, or other Camaro 6s with the Recaro option?
I noticed that on some other cars I had - BMW M3, AMG C63 - those seats had some adjustable lumbar pad that I would always "max out" to give my lower back some cushion. With my ZL1, I seem to get back pain starting even on 1 or 2 hour journeys.
Well, I pulled the trigger on a possible solution.
Gooogo 2Pcs Leather Carbon Fiber Leather Sport Car Seat Chevy Camaro ZL1 Neck Rest Pillow Foam Headrest Travel Cushion Travel Sleeping Cushion
Let me know if have this same issue and what solution you've employed. Thanks.
Plasar is offline   Reply With Quote
Old 07-23-2023, 12:19 PM   #2
Plasar
Aha, I usually search before I post, but didn't this time: I found a few other posts calling out the same. I'll let you know how these pillows work - and how cheezy they look in person!
2SS 1LE Recaros... lumbar support?
Uncomfortable seats?
Recaro Seats
Old 07-23-2023, 12:21 PM   #3
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Nope mine fit me like a glove. No need for extra padding.
Old 07-23-2023, 12:26 PM   #4
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
I wish my ZL1’s Recaros had a bit more lumbar support, but I would probably be more annoyed with a pillow behind me than it’s worth.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 07-23-2023, 02:44 PM   #5
Hey Plasar, check out this thread for a very promising power lumbar solution: https://www.camaro6.com/forums/showthread.php?t=587273
I am planning to do this one day, the reason I haven't yet is because I'm still considering the 1LE Recaros as well.
Oh, and here is a much more OEM looking lumbar switch that GM actually uses in several other cars/SUVs, I am going to install this one instead of the generic switch in the above thread: https://www.gmpartsdirect.com/oem-pa...witch-84445926 (part number 84445926).
Old 07-23-2023, 02:45 PM   #6
az4783054
Drives: SWXXZL1
I've had Recaro seats in Mustangs that definitely needed lumbar support. I found lumbar bladders online which use a hand held squeeze bulb to pump air into the bladder. You have to remove the seat back upholstery to install the bladder, position it optimally and secure it under the upholstery cover. The squeeze bulb has a release valve similar to a doctors sphygmomanometer for measuring blood pressure.
You can find several offerings by searching the internet using search terms like "inflatable bladder lumbar support for bucket seats".
"Joe" does a hilarious impression of a slinky toy on stairs.
az4783054 is offline   Reply With Quote
Old 07-23-2023, 07:04 PM   #7
ZPirate
ZPirate's Avatar
Mine do as well.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 08-07-2023, 01:02 PM   #8
Plasar
Thanks for all the replies! And Arpad, I appreciate the link to the custom solution in the forum. I think I’m too lazy to go to that level of awesomeness.
Update: I got the pillows. Of course, these are meant for the headrests, thus they have a tight elastic strap attached. They will not stretch enough to fit around the widest part of the seat back- so I can’t affix them in the lumbar area. But for what it’s worth, they work OK as extra support for your lower back, I tried out for 2 x 1.5 hour drives, they helped, and the quality looks good.
I recommend them as a quick and cheap work around.
Old 08-07-2023, 07:02 PM   #9
I don't know man, please don't take it the wrong way, but I wouldn't want to be seen with these in the car The power lumbar solution is pretty involved indeed, I'm holding off on it, too, so we're in the same boat, heh...
Old 08-07-2023, 07:39 PM   #10
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
Old 08-08-2023, 11:14 PM   #11
Plasar
You folks are ruthless - you are making it seem like I bought this on the QVC Channel and I’m secretly stashing adult diapers in these things!
Old 08-08-2023, 11:33 PM   #12
Old 08-09-2023, 07:31 AM   #13
cjperformance
cjperformance's Avatar
Haha, you gotta do what you gotta do. Learned long ago not to give a sh!t what others think. Back pain sucks. Well all pain sucks... but like someone has grabbed ahold of your spinal cord with vice grips sometimes.
Just stash em in the rear footwells when you arent using them. No human can sit back there anyway so the secret is safe.
I have to say they look a little to small and "cute" to be cool, but again if they work they work.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 08-09-2023, 11:39 AM   #14
sactownbwoy
Drives: '22 Camaro ZL1 1LE A10
I might pick up a pair for car shows, they are that extra touch that sets you apart .
sactownbwoy is offline   Reply With Quote
