Go Back   CAMARO6 > Marketplace > Members Classifieds > V6 - Engine, Exhaust, Bolt-Ons, Tuning Equipment
Old 07-23-2023, 01:36 AM   #1
Shenron
Drives: Chevy camaro
LGX Overkill Supercharger Stage 1
P1SC-1-H (helical gearing) procharger supercharger
Asking: 4000$
——PRICED TO MOVE!!—-
Has 4,450 miles on it, has had three oil changes, first at 400 miles, second at 2k and the third at around 2k. (Intervals were a bit longer but i wanted to be on the safe side)
Includes: all spacers, face plate and engine mounting brackets, supercharger belt (used)
Cobra heads with venturi barb
Full intercooler piping (including blow off valve)
(All rubber lines needed) can provide extra aswell.
Maf extention cable (all baggys are marked for easy installation)
All t bolt clamps needed.
True cold air intake for the supercharger, my wheels rubbed on the tubing a bit as my wheel setup up front was too big, and filter will probably need replaced though i was running it with the filter.
Throttle body spacer with two taps for suction, one for the catch can, one for the bov and longer bolts to fit it up
Intercooler (kind of banged up, worked fine though) if you wanted to replace it, expect 120$-200$ for a new one. If you don’t want the intercooler, i will take 200$ off the price.
Tracy lewis catch can with check valves for forced induction setup and all lines.
——DOES NOT INCLUDE CRANK PULLY BECAUSE I CAN’T GET IT OFF—
You will need a 6th gen camaro crank pully for the independant belt. Tracy lewis will sell you the crank pully you need for 250$.
Price includes shipping.
Shenron is offline   Reply With Quote
