07-20-2023, 10:25 AM | #1 |
Drives: 2022 Camaro LT1 Join Date: Nov 2022
Bang for the buck
So I have a 2022 Camaro LT1. Been looking at the Magnuson 2650 kit they sell for the Camaro. looks like a no brainer for the money. 588 hp and 600 ft-lbs at 8 lbs of boost. they also include a tune. cost 8500. Don't have to change anything else. Yes I know the 2650 is way more potential. But a simple bolt on seems much more appealing than major engine work. As this is my daily driver.
So my question is to achieve the same gains I would assume you would need several internal changes to get the same. Cam , Heads, different intake , Different fuel system? not sure. and cost? |
07-20-2023, 12:48 PM | #2 |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
Are you going to keep the boost at 8PSI? You may want to look at upgrading your fueling (LT4 stuff or port injection). Install a flex fuel kit to run E85. If you plan on turning up the boost, then you will need to build the bottom end as well- forged internals. May want to consider the LT4 supercharger (stock on ZL1s)- a cheaper option for the 600rwhp range.
Lots of choices.... Maggie, Whipple, Procharger.... the list is long and the mods to your car can get deep quickly. There are so many discussions/threads regarding this in the Forced Induction Discussions forum, so please search for your answers
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
07-20-2023, 02:02 PM | #3 |
the whole point was not having to do any other mods other than bolt on. Yes I know if you start adding boost then other components come into play.
what I'm trying to figure is 180 some HP gain with a simple bolt on can be done for about 8500. To get the same HP NA. would be what? and how much to get there? more or less than the 8500 |
07-20-2023, 04:02 PM | #4 |
Drives: 2022 Camaro zl1 Join Date: Jun 2023
I would think at the very least you are looking at head work possibly aftermarket heads, cam, long tubes, intake, throttle body, e85, maybe some meth and a really aggressive tune. No idea if that would hit it or if the fuel system would be able to support all of that...probably looking at some fuel system work too.
Dunno, I am by far one of the least knowledgeable people on here. |
07-20-2023, 04:25 PM | #5 |
07-20-2023, 06:50 PM | #6 |
LT4 supercharger swap for 5k. Take the savings and put it towards a fuel system. The 2650 isn't going to show any advantages over the LT4 until you are pushing far more power than the stock bottom end can handle.
2016 NFG 1SS A8
07-20-2023, 08:33 PM | #7 | |
Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE Join Date: May 2016
NA vs. Maggy
