07-16-2023, 05:49 PM | #1 |
Drives: 2022 Camaro zl1 Join Date: Jun 2023
Quick switching tunes?
One of my buddies has a built vw and he is able to change his tunes at the touch of a button. Like he has his daily driving tune and then various race tunes where he is changing the boost amount and timing advance pretty much on the fly.
Has anybody here put together something like that for the gen 6 camaro? |
07-17-2023, 06:14 AM | #2 |
Maybe efilive has something like that
07-19-2023, 10:32 PM | #3 |
Drives: 2020 Camaro SS 1LE Join Date: Apr 2022
Im pretty sure that VW is running a piggyback tuner which is able to switch on the fly because it’s modifying the signals to the engine to “trick” it live. All the tuners ive seen for the camaro ar a flash tune where the ecu is resetting with the new tune file being downloaded to it so its like resetting a computer where it needs to turn off.
07-20-2023, 06:22 AM | #4 |
The efilive dsp is only for e98 diesels for some reason
07-24-2023, 04:31 PM | #5 |
Drives: '16 2SS M6 Join Date: Aug 2019
Mountune has switch on the fly tunes also. I have it on my Fusion, it's cool. It has a low traction/bad weather tune that cuts the boost down to like 5psi, it has a bad gas tune that pulls a few degrees of timing, then the full power tune. Uses the cruise control button and the tach to tell you what tune you are on.
I think this has been brought up before but I haven't seen switchable maps for the Camaro.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
07-24-2023, 07:51 PM | #6 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
LOADING tune files from your cell phone
You can get this from a STOCKING distributor of HPTUNERS software. There are not that many stocking distributors but I know AMP is one of them in my area . I will be getting mine THIS week and I be posting up a video on it. The IPHONE app that allows this to happen is called Tune Delivery Network (in apple apps). This is what allows tunes to be sent back and forth through the OBDII HP tuners interface to ANY IPHONE running this APP. I just downloaded this to my iphone . SEE BELOW for the initial screen in Tuner Delivery Network APP. Here is MORE info: https://www.instagram.com/p/CuiMh0Rusld/ Here is MORE info from the HPTUNERS website: https://www.hptuners.com/mpvi3/
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 07-24-2023 at 08:46 PM. |
