07-13-2023, 01:49 PM | #1 |
Drives: 2017 2SS Camaro Join Date: Jul 2017
Water Spot Remover
Any recommendations for a good water spot remover?
I decided to hose down the car and did not wipe it off. Later there were water spots that I could not remove. Next time I will just wash the car and dry it off. Lesson learned! |
07-13-2023, 07:32 PM | #2 |
I use the SB3 Destroy calcium/water spot remover, it works like magic. Used it on wifey's mosaic black metallic SUV, and it removed already hardened spots in a few minutes. Just follow the instructions.
https://www.sb3coating.com/products/destroy-16oz
07-13-2023, 07:40 PM | #3 | |
Drives: 2019 1SS M6 Join Date: Feb 2020
1st Gen ground effects kit GBA black , GM CAI , Velossa Ram Air, Expel PPF, illuminated door sills, Upgraded door panels with spectrum lighting
07-13-2023, 09:55 PM | #4 |
if they are pretty fresh just try some 50/50 distilled water and white vinegar
remember about waterspots. If they are on long enough they will etch in. So even if the waterspot remover doesnt look like it removes them. It removes the minerals that have been left behind that is needed. What would be left is the scarring from it etching into the paint and would need polished to remove them. So just because some waterspots dont look like any improvements from the waterspot remover, it removed the minerals so they will no longer cause anymore damage to the paint.
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22 New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17 8/24. IT HAS ARRIVED at the dealer 8/25- It is in the Garage ACS ZL1 Sideskirts, 20% tint, CAI Intake |
08-18-2023, 07:27 PM | #5 |
Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
I just recently picked up my car. First black car I ever owned. I thought it would never look dirty but boy oh boy did I learn it's the exact opposite! So ahhhh, I picked up a good spray bottle and filled it with vinegar for the water spots
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock FJB |
08-18-2023, 07:46 PM | #6 |
Yeah, no use in engaging with an "AI" bot.
