07-12-2023, 03:55 PM | #1 |
Drives: '23 LT Vert M6'16 Hyper 2SS Vert MT Join Date: Sep 2016
Will 305/30/19's Fit a LT-1?
Found some Apex/Sumitomo wheels. Will these fit without spacers or rub? (other thread asked, but I didn't get a clear response. the 305 upfront is my biggest concern.)
TIA, Joel |
07-12-2023, 04:18 PM | #2 |
Disregard/delete. I just spoke to Apex (nice guys); they said without messing with the camber, the 305's up front will stick out over 1" and likely rub.
Back to shopping, lol. |
07-14-2023, 07:20 PM | #3 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Well...305/30/19s will easily fit up front without poke if you get the offset correct. You need to replicate the 1LE offset of 20mm. 23mm will work too, especially since you don't have magride. I have autocrossed on this size a lot with 19x10 and so have almost every 1LE owner. Needless to say, they will fit in back too with proper offset.
Matt Miller
2020 SS 1LE |
07-17-2023, 12:29 PM | #4 |
Drives: '23 1SS 1LE Join Date: Jul 2019
What tires do you run to be able to comfortably fit 305's on 10in rims?
I thought 10.5in was the smallest you could go for 305's without pinching. Been looking at square 305 setup to track without extended lugs. |
07-17-2023, 03:24 PM | #5 |
The wheels I found were 11" squared; I think that was the problem, they wouldn't fit up front.
07-17-2023, 10:52 PM | #6 | ||
Matt Miller
2020 SS 1LE |
07-18-2023, 11:13 AM | #7 |
Understood. Seller on the 19x11's didn't know the offsets, so they were likely squared. Staggered is probably the easiest for me at this point since I won't track much, if at all.
