Old 07-10-2023, 02:13 PM   #1
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
TRANS Cooler Upgrade for SS A10
This was posted in my MEGA Thread located at:
https://www.camaro6.com/forums/showt...1#post11334361
LOOK AT POST 312
Thought it belonged here as well.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 07-10-2023, 04:37 PM   #2
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
This is awesome to know. I just picked up a 2022 Camaro LT1 A10 and I would like to get a higher stall someday if they work well in these trans. Haven't found anyone who runs one yet. Anyway, a bigger cooler would be a plus. So the ZL1 cooler uses the same bolt holes/location but the underneath just needs to be cut out? Sounds good to me!
Dynamical is offline   Reply With Quote
Old 07-10-2023, 04:46 PM   #3
sr71bb
sr71bb's Avatar
YEP, that's what I was told by AMP. I will confirm that in next couple of days when they do the install.
Retired Cars BELOW:
Old 07-10-2023, 04:49 PM   #4
Dynamical
Dynamical's Avatar
DUDE that would be GREAT if you could post some pics
Would you happen to know if there's any BTU ratings on both SS and ZL1 coolers?
Old 07-10-2023, 08:00 PM   #5
sr71bb
sr71bb's Avatar
I didnt see any BTU specs.
Retired Cars BELOW:
Old 07-13-2023, 08:17 PM   #6
sr71bb
sr71bb's Avatar
PICS posted of ZL1 A10 tranny Cooler
POST 315 in my MEGA Thread now has PIC of installed Zl1 A10 tranny cooler.
Retired Cars BELOW:
Old 07-14-2023, 07:16 AM   #7
Dynamical
Dynamical's Avatar
Nice! I’m interested in results. It should help.
I haven’t looked at my car I just bought yet so I have a question. Do these cars have trans lines going into the radiator in addition to the trans cooler?
Old 07-14-2023, 09:15 AM   #8
sr71bb
sr71bb's Avatar
I have UPDATED this response below with more specific info.
In fact the is no tranny line that goes to the radiator in POST 10 below
Retired Cars BELOW:
Old 07-14-2023, 09:18 AM   #9
Dynamical
Dynamical's Avatar
YES, they have BOTH.
Alright. Thanks! I'll be looking into doing the bigger cooler in the future.
Old 07-14-2023, 01:40 PM   #10
sr71bb
sr71bb's Avatar
OK CORRECTION!!! It appears that my A10 uses ONLY the parallel cooler and DOES not have a line that goes to the radiator. This is more efficient since the AT line doesnt have to go thru a radiator that is being pre-heated by hot water.
The SAFE temp levels for BOTH AT Fluid and Water are about the same or around 220 degrees. The HIGHEST I have since water temp even on a VERY HOT track day is around 212 degrees and that is PRIOR to me installing my hood vents. ON day to day driving, the hood vents appear to make about a 5 degree REDUCTION in water temps.
The hottest I have seen though with tranny temps is around 250 degrees and that SPECIFICALLY is the reason for the change to the ZL1 tranny cooler.
I will post up the MAX temps that I see on both after this weekends blazing hot SCCA Time trials on Saturday.
Retired Cars BELOW:
Old 07-14-2023, 01:41 PM   #11
sr71bb
sr71bb's Avatar
deleted duplicate post
Retired Cars BELOW:
Old 07-14-2023, 02:08 PM   #12
Dynamical
Dynamical's Avatar
On my 4thgen I always had the aftermarket trans cooler doing the job by itself. I never wanted to have the 2 connected. Some say it's better to use the radiator in addition to the aftermarket cooler but I never had any issues. I ran a MASSIVE summit racing fin+tube cooler.
I realize you have yours either disconnected or it didnt come with the cooler in the radiator but I guess my specific question is, do these cars come from the factory with a trans cooler/warmer in the radiator? I know they at the least have the trans cooler in the lower area of the nose of the car.
Old 07-14-2023, 02:14 PM   #13
sr71bb
sr71bb's Avatar
Well I have a 2019 SS and apparently it NEVER had a line going from the tranny to the radiator from the factory It ONLY uses the parallel cooler.
Retired Cars BELOW:
Old 07-14-2023, 02:41 PM   #14
Dynamical
Dynamical's Avatar
Interesting! I'll be looking at my A10 in a few wks. I'll see if mine came with it. I would rather it NOT have
