Go Back   CAMARO6 > Marketplace > Members Classifieds > Suspension / Chassis / Brakes
Old 07-09-2023, 09:40 PM   #1
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
sold - delete
SOLD
Katech_Zach is offline   Reply With Quote
Old 07-09-2023, 11:03 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Would separate front pads?
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 07-10-2023, 08:01 AM   #3
Katech_Zach
I can potentially. PM me with an offer
Old 07-13-2023, 04:41 PM   #4
Osbornsm
Drives: 2018 SS 1LE
Someone BUY THIS!!!
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 07-17-2023, 07:07 PM   #5
mcbat8
Drives: 2022 SS 1LE
I think C7 Z06 front caliper is same as SS 1LE not ZL1 1LE.
mcbat8 is offline   Reply With Quote
Old 07-17-2023, 08:49 PM   #6
Briland_1LE
Briland_1LE's Avatar
Drives: 2020 Camaro SS 1LE
If those rotors will work on my ss 1LE with the OEM caliper im interested in those.
Briland_1LE is offline   Reply With Quote
Old 07-18-2023, 08:52 AM   #7
Katech_Zach
You are correct, thank you for that. C7 Z06 is a BC-61, and the ZL1 is a BZ-61
Old 07-18-2023, 05:08 PM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
If I’m not mistaken the BZ’s are the same as a CCM caliper.
Orange Krush II
Old 08-14-2023, 11:30 AM   #9
Katech_Zach
Bump
Old 01-09-2024, 12:05 PM   #10
alphaZzang
Drives: 2019 Camaro SS
Will it be a direct swap to 6th gen Camaros?
(C7 Z06 Caliper, Disks)
alphaZzang is offline   Reply With Quote
Old 01-10-2024, 12:17 AM   #11
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Calipers are a direct fit but I believe you’ll have to swap the rotor hats if you have a 2pc rotor.
Orange Krush II
