Old 07-08-2023, 05:49 PM   #1
CYN_CRVR
CYN_CRVR's Avatar
Drives: 2023 RS
Lightbulb Tip to keep spare from moving around in trunk (part number + photos)
I have a Modern Spare in my trunk, and I wanted to keep it from bouncing over road bumps or sliding around during hard cornering.
The first thing I tried was a trio of adjustable length spring-loaded curtain rods (first photo). This accomplished the goal; however, due to their design they would create an audible buzz/rattle during high-rpm deceleration.
The second thing I tried - and what I recommend - is a steel turnbuckle (McMaster Carr p/n 2996T16) with a rubber vacuum cap slid over each end. See 2nd and 3rd photos for implementation. You don't need to crank it super hard or anything; just tighten it enough so it's exerting a constant pressure, and check if it needs another half turn a day later as the rubber compresses. It's maybe not obvious from the photos, but both ends are riding along a corner so they can't slide away. And of course this is removable in seconds if you need that space for storage.
CYN_CRVR is offline   Reply With Quote
Old 07-08-2023, 06:16 PM   #2
JTS
JTS's Avatar
Drives: 2023 ZL1 A10
Nice job thank you for the post , I as well want a spare , when I leave town , I like to as you to cover my bases . I was on Moderns Web site last week , and see there spare for the ZL1 is available now
I'm sure both your F &R tires fit in your trunk or at least in you back seat .
ZL1 F I believe will fit the trunk , but the back won't.
Thanks again for sharing and I hope you don't mind if I ask a question, in your post .
I think it will barely fit in the back seat , passenger seat forward , tight but herd you can get it back there .
Question:
Has any ZL1 guys tried the fitment , rear tire in back seat?
2023 ZL1 A10 Shadow Gray Metallic
JTS is offline   Reply With Quote
Old 07-08-2023, 06:28 PM   #3
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
What is that round thing in the trunk of your car?
Old 07-08-2023, 06:32 PM   #4
CalgaryZL1
CalgaryZL1's Avatar
Seriously though I just have a puncture repair kit and a 12 V tire inflator, and it actually does fit in the trunk under the trunk floor panel
Old 07-08-2023, 08:17 PM   #5
CYN_CRVR
CYN_CRVR's Avatar
Drives: 2023 RS
Originally Posted by JTS View Post
Question:
I recall reading in another thread that the ZL1 rear tire will only fit in the front passenger seat. I cannot confirm, though.
Some flats can be fixed with those puncture repair kits; others cannot. Last year I cut a corner too tight on a canyon road, and a sharp rock took a gash out of my sidewall. We also have potholes around here that can cause a lot more damage than a nail or screw through your tread.
Old 07-09-2023, 04:30 PM   #6
JTS
JTS's Avatar
Thank you for your response, I recall reading that , now that you mentioned . The wife will half to ride in the back seat . Not every tire issue can be fixed with a plug , why I'm getting a Modern spare.
Old 07-09-2023, 07:44 PM   #7
Pickles
Drives: Audi RS3
Question:
1.Will the rear 305 tire of the ZL1 fit in the rear seat? I've asked this question before, but no-one knows or has answered with certainty!
2.Will a ZL1 305 tire fit in the front passenger seat?...again, no-one has answered with any certainty!
This question is vital for anyone travelling in remote areas ( we have plenty in Aussie!), because whilst it's good to have a spare in the trunk that will fit front & rear of the ZL1, what do you do with the punctured rear wheel & tire if it is unable to be placed anywhere in the car?
It would be good if some-one could try a "test fit" of the 305 tire inside the ZL1 to see if in fact it can fit, anywhere!
Pickles is offline   Reply With Quote
Old 07-10-2023, 02:25 PM   #8
JTS
JTS's Avatar
I'm not trying to put something on someone, I can surely do and I can , just was wondering if someone has already tried fitment, or had a situation where it had to be put in the front seat or fit in the back.
Another option is , I could buy 2 front ( take offs ) and run the same size front , change out before we leave on any trip. That way fit in the trunk , or for sure in back seat.
