Old 07-06-2023, 04:53 PM   #1
Orifice
Drives: 2016 camaro ss
release bearing noise
Hey all,
repaced stock bearing but i hear this rolling type of noice at idel. When i depress the pedal the noise is gone, idk if need to be bled more, i had opened the bleeder a few times and also powerbled it from the top i had vacuum and reverse vacuum on the reservoir, also 2 person method. Someone mentioned this maybe the self bleed type pump it about 150 to 200x but no luck any thoughts?
Orifice is offline   Reply With Quote
Old 07-06-2023, 04:58 PM   #2
Orifice
https://youtube.com/shorts/kmJiCNcsoDo?feature=share
Old 07-07-2023, 11:16 AM   #3
ctrlz
Originally Posted by Orifice View Post
When i depress the pedal the noise is gone...
Some more info might help, like why you replaced the throwout bearing.
Anyway, this sounds to me like you have possible bad bearing within the transmission. pressing the clutch pedal disengages the input shaft on the transmission.
if you have noise at idle with clutch pedal not depressed, I would guess transmission input shaft bearing.
Old 07-07-2023, 06:30 PM   #4
Orifice
possibly but the noise doesn't sound that internal...
someone had pointed out the stock bearing wasn't exactly a flat face you can see what I'm talking about here,maybe this is also part of the issue.
https://youtube.com/shorts/SozhMnnXRqc?feature=share
this video wasn't made for this but you can see the difference in the bearing tip maybe it matters
