Old 06-29-2023, 12:20 AM   #1
Dmoney2SS
Drives: 2022 summit white Chevy Camaro 2SS
Will these wheels fit
Found a set of bc forged wheels 20x9.5 +20 offset and 20x11 +40 offset, would those offsets work for our cars? The wheels are coming off of a bmw M4 I believe and my car is a 2022 2SS
Dmoney2SS is offline   Reply With Quote
Old 06-29-2023, 06:42 AM   #2
LTfun
Drives: 2022 LT1, 1981 320i
Should fit nicely. 20x10 +22 is near the limit of what you can fit in the front (on non ZL1 front fenders), without a few tricks. So the front should be good with a little bit of room to spare. The rears look good too. I think stock ZL1 (same rear fenders as everyone) is 20x11 +43 so you'd technically have 3mm more poking out but that should be fine. Do consider tire sizes though as that will also come into play. Lastly don't forget that while both BMW and our Camaros are a 5x120mm bolt pattern, that center bore is probably not the same. Our cars have a CB of 66.9 (67.1 depending on who you ask), so as long as the BMW wheels have larger CB you can purchase hub centric rings to mate them up, no problem.
LTfun is offline   Reply With Quote
Old 06-29-2023, 03:51 PM   #3
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
Everything stated above is accurate. Just make sure the center pilot bore is big enough. You don't need hubcentric rings: the tapered lug nuts and seats are what locate the wheels on these cars.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 06-30-2023, 03:38 PM   #4
Dmoney2SS
By any chance, where can I find the offsets for those wheels? I have a set of ZL1 wheels on right now, what are the front offsets? I know the rear is +43 but I’m not sure of the fronts
Old 07-05-2023, 09:14 AM   #5
LTfun
I'm sure it's been posted somewhere here before. I don't have a ZL1 but I'm pretty sure the fronts are 20x10 +23. I think the tire is 285/30 which puts the overall diameter at 26.73 inches. Also width wise, it is inset from the hub 162.7mm and 116.7mm outset or poke from the hub. Hope this helps.
Old 07-05-2023, 10:43 AM   #6
Msquared
Msquared's Avatar
The stock SS 1LE and non-1LE ZL1 wheels are 20x10 with 20mm offset. The stock tire is indeed 285/30/20. The rears are 20x11 with 43mm offset and 305/30/20tires.
Edited after mistakes were pointed out below.
Matt Miller
2020 SS 1LE
Old 07-05-2023, 11:39 AM   #7
BatMobileLT1
BatMobileLT1's Avatar
Drives: 2023 Camaro LT1 M6
Originally Posted by Msquared View Post
The stock SS 1LE and non-1LE ZL1 wheels are 20x10 with 20mm offset. The stock tire is indeed 285/30/20. The rears are 201x11 with 43mm offset and 305/30/19 tires.
Just note for clarity, I think there are minor typos on last line on rear tire info, should be:
20 x 11
305/30/20 tires
2023 Black LT1 – M6, Dual Mode Exhaust, Sunroof, Tech Pkg w/Bose Audio, Red Front Brake Calipers, Carbon Flash Wheels, Ground Effects & RS Pkg
Added after delivery: Continental ExtCont DWS06+ Tires: 245/40/20 Front & 275/35/20 w/9.5” Rear Wheels, Red Rear MGP Caliper Covers
BatMobileLT1 is offline   Reply With Quote
Old 07-05-2023, 12:26 PM   #8
Msquared
Msquared's Avatar
20 x 11
305/30/20 tires
Dammit! You're right, of course. I corrected the post above to avoid causing more confusion. Thanks for catching those.
Matt Miller
2020 SS 1LE
