06-24-2023, 09:03 AM | #1 |
Drives: 2023 SS w/ 1LE Join Date: Jun 2023
Brembo rear brakes squeking
Hello,
I recently bought a 2023 SS with 1LE package. After a couple hundred miles I noticed a horrible squeking sound coming only from the rear drivers side region when decelerating between 30-15mph. I kept driving on it hoping it was normal break in and would go away. The sound volume did seem to go down but it continued enough to annoy the sh*t out of me. This week I took it to the dealer and they applied a copper paste to the pads (only on the rear drivers brake pad) based on GM Bulletin 17-NA-040. At first it was quiet like a mouse and I was tickled, but after driving on it about 30 miles occasionally it comes back, though definitely not as loud. It is still annoying, and I don't know when or if its going to happen but its annoying enough. The vehicle is brand new, and should be perfect, and it is not perfect. Is there a permanent fix/solution? Any assistance is greatly appreciated. |
06-24-2023, 09:18 AM | #2 |
BanHamWatch
Drives: 21 ZL1 1LE Join Date: Jan 2021
The fix is to use the brakes hard and often. If you soft on them they just glase up and that’s a common outcome
2021 ZL1 1LE
Auto |
06-24-2023, 10:54 AM | #3 |
Drives: 23 ZL1 6speed Join Date: Aug 2020
Have you tried some WD40 ��
“Straight roads are for fast cars, turns are for fast drivers.”
Gone but not forgotten: ‘17 Camaro 2SS Yellow 6speed |
06-24-2023, 11:01 AM | #4 |
2018 SS A8 11.85@117.06
Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake |
06-24-2023, 11:05 AM | #5 |
06-24-2023, 11:08 AM | #6 |
Performance brakes will often squeak. As with other performance items, it can actually be “worse” to not use something… versus stretching its legs once in awhile. The sound will go away, or reduce, if you use the brakes.
06-24-2023, 11:23 AM | #7 |
17’ Hyper Blue 2SS
Usually if you use the break in method it solves it, find a nice empty road, take her to about 55-60 and lay into them fairly heavy, repeat 3-4 times.
06-24-2023, 11:35 AM | #8 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
#becauseracecar
06-24-2023, 04:15 PM | #9 |
Buy some power stop extreme brake pads and follow the break in instructions. That way you don’t have to clean your wheels every time you drive it
06-24-2023, 05:18 PM | #10 |
BanHamWatch
I have the power stops however they are inferior to the stock pad’s however yes no dust in comparison. Unfortunately I track the car and the power stops are a hard NO
2021 ZL1 1LE
Auto |
06-24-2023, 10:24 PM | #11 | |
Old school tech
Drives: Ruby 1LE - 2024 2SS 1LE Join Date: Mar 2014
Previous Camaros: 2021 Riverside Blue 2SS/RS A10 | 2019 Riverside Blue 2SS/RS M6 | 2013 Crystal Red 1SS/RS A6 | 2010 Imperial Blue 2SS/RS A6
One & only Corvette: 2015 Stingray Z51 Ordered 2024 Radiant Red 2SS 1LE Ordered: 6/15/23 Accepted: 7/5/23 3000 - 7/5 ---> 3100 - 7/19 3300 - 7/20 --> 3400 - 7/20 -->TPW - 8/7 4300 - 8/14 --->4B00 - 9/5 DELIVERED 9/20!! |
06-25-2023, 10:35 AM | #12 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
I haven't lubed the pins for years and never have the rear brake pads squeaked except maybe slightly on a cold day before they warm up. The service manual doesn't call for lubricating the pins, just the top and bottom edges of the rear pads as pictured above.
If you track the car ceramic extreme (like Permatex 24129) is the only bake lube I have found that won't get too hot and disappear after track use. Also if you spray the brake calipers directly with a pressure washer while washing the car that might wash away the lube and cause the squeaking. |
06-25-2023, 10:43 AM | #13 |
I have been doing brakes for many years I would polish ( wire wheel ) all the hardware and wipe the pins down with high temp brake grease. just clean up all contact points with wire brush lightly lube and assembly good as new.
DARK KNIGHT
