![]() Drives: '22 Camaro 2SS/1LE Join Date: Nov 2021
94 Octane. Yay/Nay?
I never run anything less than 93. I've noticed a Sunoco near my job that sells 94. Curious if it will make a difference in any 'snap' or fun with the car as a treat here or there?? Besides the wallet, any damage it could cause? Only mechanical mod I have is a Rotofab intake. Thanks!
'22 2SS/1LE, M6, Wild Cherry Tintcoat, PDR, Sunroof
11/1 - order submitted to GM - 12/26 - order accepted by GM 1/7 - TPW 1/24 1/13 - TPW 1/31 2/9 - 3800 - BUILT! 3/2 - 4300 3/14 - 4B00 3/19 - per Chevy chat - finishing up final testing and approvals - dealership ETA 4/16/22 3/29 - 4200 - dealer ETA 4/23 4/5 - 5000 - but can't pick up for another week 4/16 - 6000 - Home Sweet Home Daily driver... '23 Mazda CX5/Premium Plus (dealer demo) |
![]() Drives: 23 2SS 1LE Join Date: Feb 2019
There is no change in energy, but could help with knocking if you just had an issue with it running 93, but you shouldnt. If its the same price, go for it. If its more expensive then you are just wasting your money.
Instagram: RideWithDanger
Current Mods: Rotofab, Ported LT2 intake, LT5 TB, Kooks Headers, AWE Touring Catback Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
It gives you the ability to compress the gas/vapour more without pre-igniting and when used in the correct engine and tuned properly you will get more power and avoid knock. I run 94 with octane booster in a half tank that gives me 98 octane. It’s the cooling effect we want in order to keep our timing up on pulls/races. Sorry a bit off topic but if you can afford it and have mods to support higher octane, go for it.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
Your case 93 is fine with a stock set-up.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
If it's not knocking at 93, using 94 or higher will not improve anything.
"KEEP THE FAITH"-Fbodfather |
Won't cause damage other than to your wallet, as you said. Highly unlikely you will notice any change in performance. In theory, an engine optimized for 93 will develop slightly less power on 94. This difference may not even be measurable with sophisticated equipment because 93 and 94 are so close.
If curiosity is killing you the best way to try it is to finish the tank of 93 and fill up on 94. |
#7 | |
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#8 |
Moderator
LT1 and LT4 engines live off the knock sensors even bone stock. Zero drawback to running a little extra octane, especially in hot weather or heavy load conditions.
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
The extra octane will certainly help. Depends on the Cost if the 1 pt is worth it to ya.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
I've been running it for the last few years when I run across it.
No noticeable gain on stock car. I run Sunoco exclusively, no other reason than consistency as there are some shady stations around here. Price is the same as 93.
'18 1SS 1LE Black, PDR
#11 |
![]() ![]() ![]() Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Does the pump say what percent ethanol the 94 octane is? The manual says you can use up to 15% ethanol and normal 93 octane is up to 10% ethanol.
With the Camaro's 19 gallon fuel tank you could mix 1 gallon of E85 with 18 gallons of 93 octane E10 gas to make your own 93.6 octane E14 gas. Note that you would probably have to adjust the ratios a bit to do this yourself since it is difficult to completely empty the 19 gallon fuel tank without running out of gas. Maybe this type of E15 mix is what that Sunoco gas station is selling. |
#12 |
![]() Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
no unless you tune for it and even if you tune for it, the tuner may get a degree out of it or maybe not netting is zero to maybe a HP or 2.
#13 |
The Sunoco 94 around here is 10% ethanol.
#14 |
There was a Sunoco station that had 92 pure gasoline, no ethanol last summer.
My question would be, is 92 pure gasoline better than 93-94 with the ethanol mixed in?
