![]() Drives: 2018 Chevrolet Camaro 2SS 1LE 6M Join Date: Jul 2019
Oil leak from oil cooler/warmer.
Just a quick post about an oil leak I found on my 2018 Camaro. The engine was leaking from the oil cooler/warmer thing which bolts to the oil pan. I got the o-rings from my local Chevy dealer and installed them. During the install I noticed that the top bolts were not tight-there are 4 bolts in total on this thing. The bolt on top and at the front of the cooler was barely more than finger tight. With the new o-rings in place and the 4 bolts torqued, the leak is gone.
Bolt-ons.
Glad you got it squared away. You are not the only one to find loose oil cooler bolts. Many have also found loose oil pan bolts as well.
![]() Drives: 2018 2SS 1LE 416 NA Join Date: Feb 2021
Do you remember the part number for the O-rings?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
My 18 had loose oil pan bolts, probably got a full turn on them and my leak went away.
12698626.
$8.48 each-list.
Bolt-ons.
thank you
