Old 06-22-2023, 01:26 PM   #1
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
anti-slip pully/belts?
did a search and came up with nothing concrete. Now that I can address my concern of the P0300 issue (where I'll need to start) my next step is to address obvious belt slip. during a hard pull on the highway I can clearly feel that there is belt slip. right now, I am on the belts that Magnuson sent me, I do however, have a 1 smaller pully down 95mm.
-looked at Magnuson's site and not really knowing where to go/need.
-thanks for your advise.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 06-22-2023, 01:43 PM   #2
JasonGofast
Used to own a ZL1
Drives: '16 Z06
Griptech pulleys are really good. Rpm/Gates Green belts is what everyone uses for belts. You probably just need a smaller belt considering you went down a pulley size. Shouldn't be getting any belt slip with a pulley that big.
JasonGofast is offline   Reply With Quote
Old 06-22-2023, 03:21 PM   #3
oneredry
HYPER SS
oneredry's Avatar
Great thanks!
Ordered: 1/15/2016
Delivered 03/23/16
Old 06-22-2023, 03:55 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
ZPE makes the griptec stuff so you can just order right from them instead of paying a markup somewhere else:
https://www.zpegriptec.com/
I’ve had great luck with Dayco belts. The one time I didn’t use it, the belt broke FWIW. Many of theirs are American made too. But Gates is obviously great too.
Keep in mind most people see 1.0-1.5 pounds of additional boost going from a regular pulley to a griptec. Something to keep in mind if your fueling is on the edge.
Old 06-22-2023, 04:59 PM   #5
JasonGofast
Used to own a ZL1
Drives: '16 Z06
Lol are their pulley measurements wrong or do they grip the belts that much better?
Old 06-22-2023, 08:47 PM   #6
Joshinator99
Moderator
They grip the belts…thus the name my man. The belt contact surface feels like 2000 grit sandpaper. Smooth enough so that there’s no belt damage (obviously) but the reduction in belt slippage is dramatic, especially at more aggressive pulley combos. I couldn’t imagine trying my combo without it…
Old 06-22-2023, 09:19 PM   #7
JSH
JSH's Avatar
Drives: '20 ZLE
I can only tell you that the Gates K080859HD FleetRunner Micro-V Serpentine Drive Belt works great on my car with Grip tech pullies
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 06-22-2023, 09:53 PM   #8
Joshinator99
Moderator
I can only tell you that the Gates K060586HD FleetRunner Micro-V Serpentine Drive Belt works great on my car with Grip tech pullies
Are you sure that’s the belt your using…? That’s only a 6 rib belt…
Old 06-24-2023, 08:48 AM   #9
JSH
JSH's Avatar
Drives: '20 ZLE
Yea, the belt for my 3" pulley is a K080859HD. I assume my 2.75" is the same. I was looking at another belt.
2020 ZL1LE A10.
Old 06-24-2023, 10:57 AM   #10
Joshinator99
Moderator
Thought so…
