Old 06-21-2023, 07:27 AM   #1
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
P0300 supercharged high way pull?
Hello everyone, been a minute since I've posted anything. but last night was on the highway with absolute no one on the road, did a small pull coming from off the ramp to the highway, stayed into it till about 5th gear and let up (I wont' say the speeds) in anyrate, I see the check engine light flash on and off for about 45 seconds until i got off the highway. when i pulled to the stop light the light went away (went home and checked it). Keeping in mind that the car only has about 9800 miles on it, and when i was in it, I can tell that the supercharger belt was slipping as when i looked over i noticed that my boost gauge peaked at 8.4psi which I've never seen it go that high. (has been dyno tuned) a step down smaller pully has been put on, and the belt has not been replaced upon that new pully. Never really had any issues especially a misfire code. what I'm thinking is that with it being full throttle and the belt slippage (you can fell it) maybe the air/fuel wasn't getting?
- what are your thoughts? i did drive it around for a bit and light never came back on. I normally don't beat on my vehicles and thought it was a ok idea just to stretch her legs a bit.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 06-21-2023, 11:42 AM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Misfire is frequently plug or plug wire related. What are you running for those items? I’m assuming you’re on pump gas 91/93?
Old 06-21-2023, 02:37 PM   #3
oneredry
HYPER SS
oneredry's Avatar
yes 93 shell for fuel. wires are stock, plugs are ACdelco 1 step colder (the ones that the ZL1 use for boost) not the stock SS plugs.
Ordered: 1/15/2016
Delivered 03/23/16
Old 06-21-2023, 06:08 PM   #4
Joshinator99
Moderator
Was P0300 the only code? You often get say, P0304, which would tell you the cylinder that’s having the issue.
Old 06-21-2023, 07:48 PM   #5
oneredry
HYPER SS
oneredry's Avatar
good question. yes. that p0300 was infact the only code. no other code was present.
Ordered: 1/15/2016
Delivered 03/23/16
Old 06-22-2023, 06:57 AM   #6
cjperformance
cjperformance's Avatar
Replying in a hurry, so apologies if i missed a detail somewhere. You said you never saw that high of boost. Could you be out of fueling capacity? Lean miss? Random misfire, not just on a single cyl?
Whats your fueling mods?
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 06-22-2023, 09:13 AM   #7
oneredry
HYPER SS
oneredry's Avatar
its a possibility. so I'm conservative when it comes to fueling, I had this dyno tuned with HPTuners and the tuner said when he tuned it, the car was very happy right around the 7.5psi. on all stock fueling, which is what I wanted. (not because of being cheap, but i wanted a reliable with some fun) this was the best of both worlds. Now, you make a good point when what i feel like the belt slip which spiked the boost up (what I would call it) it could very well have been this.
but as i was saying, the tuner said that he could tune it a little higher but the fuel would start cutting out at 600whp or so. right now I'm right around the 570whp.
Ordered: 1/15/2016
Delivered 03/23/16
Old 06-22-2023, 09:23 AM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
belt slip isn't going to spike the boost. If the belt slips the pulley on the supercharger isn't going to spin as fast causing a loss of boost due to less rpm. You likely just need to tighten the spark plug gap up a little bit.
Old 06-22-2023, 10:19 AM   #9
cjperformance
I've been where you are. If it isn't what KingLT1 said, I'd put my money on lack of fuel despite what your tuner said. It's a RAZOR THIN margin on stock LT1 fueling. Especially on a 2016 on the low side. I was hitting 30 lbs on the low size at 7-8 psi.
Old 06-22-2023, 01:21 PM   #10
oneredry
HYPER SS
oneredry's Avatar
all makes perfect sense. thanks guys...
- whats wierd is hopefully its a 1 and done. as I've never experienced this before. only difference is. this was WOT from 2nd through 5 up till "x" mph. VS maybe light to light.
Ordered: 1/15/2016
Delivered 03/23/16
Old 06-22-2023, 02:27 PM   #11
cjperformance
If you have hptuners, get some logs. Yer a cold day away from engine damage if you are out of fuel capacity. Cold air takes more fuel... stresses the fuel system more. Long pull can make it worse too.
Old 06-29-2023, 12:07 PM   #12
JANNETTYRACING
JANNETTYRACING's Avatar
I have said this over and over, NO LT1 should get a supercharger with more than 6 psi boost without fuel system upgrades, i.e. Lt4 fuel system components.
Even at 6 psi the car will need a JMS fuel system voltage booster so the low side pump can keep the high side pump fed with that much fuel demand.
570 RWHP is the absolute Limit of fuel supply from the LT1 High pressure pump and injectors.
This leaves no room for extra fueling to supply Cat Overtemp Protection will request.
As soon as you exceed 6 ms of injector opening it will drain the high side pump and the car will misfire.
When the low side drops the high side drops hard also.
CAUTION MANY TUNERS WILL COMMAND A VERY LEAN POWER ENRICHMENT NUMBER TO STRETCH THE FUEL SYSTEM
THIS IS BAD BECAUSE IT RAISES COMBUSTION TEMPURATURES WHICH EXPANDS THE RINGS AND LEADS TO DETONATION AND PISTON FAILURE
At absolute bare minimum you need a JMS fuel system voltage booster.
But I strongly recommend an LT4 fuel system upgrade package https://jannettyracing.com/products/...2018-camaro-ss
1LE cars and 19 up cars do not require the low side pump so you can select to delete that from the package.
www.jannettyracing.com
email tedj@jannettyracing.com
