Old 06-20-2023, 04:20 PM   #1
Saberscar223
Saberscar223's Avatar
Drives: 2023 Riverside Blue 2SS
Is there really no way to disable codes?
I got Kooks 2inch headers installed and now I can’t auto start my car anymore and have to stare at the check engine light. Is there really no way to disable this? Every tuner everywhere just stop turning this light off?
There has to be SOME way to get rid of P0420
Saberscar223 is offline   Reply With Quote
Old 06-20-2023, 04:28 PM   #2
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Your tuner has to disable a few codes before start up or they will remain permanent. You will not be able to clear permanent codes.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 06-20-2023, 04:33 PM   #3
ShockingZ
Drives: Chevy Camaro ZL1
This is not true at all. But hey, internet facts...lol
ShockingZ is offline   Reply With Quote
Old 06-20-2023, 05:03 PM   #4
BlackbeastSS2
Well my 2016 SS had permanent codes from the tuner and shop that was installed my headers.
“With Cat delete & deleted AFM valves.
My current ride has no problem because the tuner/shop knew what they were doing. Fact with my own personal experience.
The OP actually already asked about codes in the thread below.
You should read this thread.
https://www.camaro6.com/forums/showt...php?p=11322553
Old 06-20-2023, 05:42 PM   #5
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Agreed this topic has been discussed at length.
TLDR:
1. Disabling P0420/P0430 BEFORE you do the install is the best way, by far.
2. If you screw up #1, I *believe* your tuner can set it to “No Error Reported” and then turn “off” the SEL. This should shut the light off BUT you will fail any plug in emissions. Permanent code territory at that point. If you live somewhere where plug in doesn’t happen, then you’re fine obviously.
3. On a 2016 (only) I think you can “Write Entire” when you flash in the new tune and get past #2. But that stunt doesn’t work on 2017-up.
Hope my old timer memory is correct on this haha!
Old 06-20-2023, 07:08 PM   #6
Saberscar223
Yeah I’m registered in a state that does no testing of any kind
